Remote Start / Alarm advise
Old Jan 22, 2012 | 12:42 PM
Ryno13's Avatar
Ryno13
Default Remote Start / Alarm advise
2005 es330
I have a new Autopage C3-RS-730 2way remote start / alarm in the box. I knew I would have to buy a module to override the anti theft. I didn't realize I would need another master key to program the module. I only have one master key. Is this true that it takes 2 master keys? Any advise on where to get a cut master key for cheap?
Old Jan 22, 2012 | 04:46 PM
Shibumi1's Avatar
Shibumi1
no need to get a 2nd key.. all u need is the Idatalink ADS-TB bypass mod it learns the from the 1 key u have to bypass oem transponder system... but u will need an authorized idatalink dealer to flash the mod with the appropriate firmware...
http://store.idatalink.com/index.php?l=product_list&c=2
Old Jan 23, 2012 | 05:33 PM
Ryno13's Avatar
Ryno13
Can that be done online or do I have to find a shop/dealer locally?
Old Jan 23, 2012 | 07:17 PM
gazi001's Avatar
gazi001
You could use PKALL bypass module without using the master key. Here is the link: http://www.amazon.com/Directed-Elect.../dp/B001N7RE44
Old Jan 23, 2012 | 08:59 PM
Shibumi1's Avatar
Shibumi1
pkall still requires 2 keys to program...."i might" work with 1 key but do u really wanna chance it?
Old Jan 23, 2012 | 09:03 PM
Shibumi1's Avatar
Shibumi1
once upon a time u could go online an flash the mod but as of aug of last yr idata requires u set up an acct to flash a module..(i have a lot of local shops, send guys by regularly so i can flash mods for them). what id suggest is whomever u buy the mod from make sure they can put the proper firmware on the ADS-TB before they ship it out.. then u can print the install guide free online...
make sure you give the shop/company u get the mod from ALL the info u have...what brand,model alarm as well as yr,mk,mdl car so they can set it up properly.. d2d (data to data) mode will save a ton of time in installing the alarm.. if not u can always go w2w (wire to wire)
dougullom
20
Jun 10, 2019 10:54 AM
Enz
RX - 1st Gen (1999-2003)
24
Aug 2, 2014 12:08 PM
polluxtroy
Jan 25, 2012 11:38 AM
MATEOGS
Feb 5, 2008 07:38 AM
bored7one4
Aug 1, 2005 08:40 PM
