Kenwood dnx 9980hd INSTALL?
Old Jun 7, 2011 | 11:27 PM
Czechlex's Avatar
Czechlex
Default Kenwood dnx 9980hd INSTALL?
Hey everyone! I just had a new Kenwood 9980 installed in my 01 GS3 and the installer can't get any sound. Said that the wiring harness doesn't match up and the system needs to to be rewired with an addtional amp for the sub. I can either buy an amp for just the sub or get a 5 way amp to power all the speakers. Has anyone had this issue? Am I getting played or is this normal for our cars? PLEASE HELP
Old Jun 8, 2011 | 01:58 AM
1sWt2GS's Avatar
1sWt2GS
amp is behind the glove box, your going to need to take apart the glove box and get to the amp
one of the harness's (i forgot which 1) is a direct plug and play you just needa run the wires back to your head unit
u can still get to play you just have to run the harness all the way to the amp and plug it in.
this method is called the amp bypass.
u should tip me for giving u this info , took me a few days to find it out!
Old Jun 8, 2011 | 07:11 AM
neojungle1's Avatar
neojungle1
go to the gs2 sticky section there a whole tread on it and other as well too.. as always use the search there ton of tread on this topic that been bleed dry no need to ask the same question over and over
Old Jun 8, 2011 | 07:14 AM
neojungle1's Avatar
neojungle1
found in under 30 sec the mother ship https://www.clublexus.com/forums/lex...ration-gs.html
baihama
Sep 19, 2012 10:09 AM
AZ IS350
Feb 8, 2007 02:05 PM
LSden
Sep 26, 2005 07:35 PM
mcnelson
Oct 28, 2003 02:44 PM
