SC400 Head Unit HELP needed
Old Aug 27, 2002 | 01:42 AM
Grimpy's Avatar
Grimpy
Default SC400 Head Unit HELP needed
Hello,
I just got a Premier head unit, a Indash Monitor from Visonik and a dvd/mp3/wma/cdr player. I also bought a Toyota wiring harness.
I take everything out. and WHAM it hits me ... WTF are all these harnesses for? I count about 4. The toyota harness came with only two.
Does any one have the color codes and/or know what goes to what?
Or does anyone know if they sell the right harness's?
Any help would be appreciated.
Thanks
Darrin
Old Aug 27, 2002 | 07:22 PM
pcmw's Avatar
pcmw
The SC's have factory amps in the rear. You need to run line-level (rca outputs) to these inputs to make it function with the stock speakers/amps.
However, you may have problems matching the levels up. The factory headunit puts out a lower than normal signal.
So...with that said... you will need a few more things to get the job done. http://209.125.175.29/lexusstereo.html that will help a ton.
You may need new amps and speakers as well.
Good Luck.
MW
Old Aug 28, 2002 | 02:28 AM
Grimpy's Avatar
Grimpy
Thanks Bro
This is exactly what I was looking for. I had another one from carstereohelp and it was different. Again Thanks.
Darrin
Old Aug 28, 2002 | 02:41 AM
AutoCoutureSC's Avatar
AutoCoutureSC
Post
i had the same problem when i put my Alpine IVA in my car. i didn't use the rca outputs to run my speakers. just tapped into the wires from the factory amp, so we used the exisiting factory wires to receive signals. i actually changed my harness to a non-lexus one so that i can change head units like any other car without having to worry about my cutting wires.
Old Aug 28, 2002 | 04:24 AM
Grimpy's Avatar
Grimpy
Im going to try to attempt this tomorrow. Thanks for the help guys.
Old Aug 28, 2002 | 12:30 PM
DriftGirl's Avatar
DriftGirl
Save yourself the headache(now and later) and jus re-wire the whole system.
~Em
Old Aug 28, 2002 | 03:42 PM
pcmw's Avatar
pcmw
"Save yourself the headache(now and later) and jus re-wire the whole system."
I agree with Emerald. If you change out the headunit, you might as well run two pair of wires into the doors from the dash. The SC is by far the easiest car to pull wires into the doors because of the double hinge system that leaves a huge gap. Then you can ditch the stock amps and get what you paid for.
MW
Old Aug 29, 2002 | 03:18 AM
Grimpy's Avatar
Grimpy
well I figured out most of it. Everything turns on. However my power antenna doesnt turn on anymore. Anyone have any clue which wires they are or anything that has to do with the wires? I tried using that chart thing but had no clue.
Old Jan 31, 2005 | 11:23 PM
dn7981's Avatar
dn7981
Anyone have a link with step by step help on installing a new head unit and hooking up speakers? thanks
Old Feb 1, 2005 | 07:19 PM
FireCode's Avatar
FireCode
search for anything I have written. here is one link for the wires you need
https://www.clublexus.com/forums/sho...d.php?t=148646
and here is another
https://www.clublexus.com/forums/sho...ermarket+Sc400
anymore questions??????????????????
XclusivOne
Jun 17, 2016 02:19 PM
jerryparks
Oct 8, 2010 06:08 PM
lexs300
Mar 7, 2008 11:39 AM
hamid
Jan 8, 2003 06:48 PM
Ali SC4
Feb 16, 2002 03:40 PM
