need recommendations
Old Sep 21, 2010 | 02:13 PM
isejay's Avatar
isejay
Default need recommendations
I currently drive an is250 and need advice for a system around $300-500. 2 subs and an amp. trying not to take too much space in the trunk. its already small as it is.
Old Sep 21, 2010 | 05:02 PM
maximus54's Avatar
maximus54
1. are you looking for sound quality or pressure level (loud)?
2. 3-500 isn't much of a budget to work with. you have to take into account: box/enclosure, amp wiring, connecting it to head unit, and installation if you can't diy.
Old Sep 21, 2010 | 08:31 PM
isejay's Avatar
isejay
i can do all the installation and enclosure will be a separate budget. just trying to get all the main components. what i'm mainly looking for is quality sound out of a subwoofer, clean, crisp bass and somewhat loud.
Old Sep 22, 2010 | 05:08 AM
maximus54's Avatar
maximus54
2 Alpine Type R 10" Subwoofers pushed by one Alpine MRP-M1000. Or one Alpine Type X Subwoofer powered by the same MRP-M1000. Personally I would go with a single Type X. Type R's can be had for around $100 a piece. Type X is around $220. MRP-M1000 is around $250.
Old Sep 22, 2010 | 12:52 PM
egggy's Avatar
egggy
500 isn't much
sundown sa-10
http://www.woofersetc.com/p9260/SA12...-Subwoofer.htm
soundstream stealth
http://www.woofersetc.com/p7757/STL1...-Amplifier.htm
Old Sep 23, 2010 | 03:25 AM
isejay's Avatar
isejay
so i'm planning to run 1 12 alpine type x, with the alpine MRP-M1000, and a 2 farad capacitor (massive possibly, unless anyone thinks that's a bad idea). with this load would the capacitor be sufficient? what are your opinions with this set up?
Old Sep 23, 2010 | 04:47 AM
maximus54's Avatar
maximus54
Don't do the capacitor. They have proven to do more harm than good. Upgrade your battery to either an optima or kinetik. and do Big 3 upgrade (upgrade to larger cables for battery/alternator grounds). Make sure you build a proper enclosure for the sub. I believe 1.25 ft^3 Sealed is what Alpine told me for sound quality.
Old Sep 24, 2010 | 08:07 AM
isejay's Avatar
isejay
so I guess I'll go with the kinteik route. how does the HC 1800 sound?
Old Sep 24, 2010 | 08:25 AM
egggy's Avatar
egggy
Go xs power
Kinetik is just an re badged odyssey batt
Old Sep 24, 2010 | 08:47 AM
isejay's Avatar
isejay
which model should i be looking for to handle the 1000 watts the amp will be needing. also when I upgrade the big 3, would using a 0 gauge wire for all 3 be a good idea? also what gauge wire for the power wire to the amp?
Old Sep 24, 2010 | 10:17 AM
maximus54's Avatar
maximus54
Get the Kinetik 1800, you want the largest size that fits the 2GS battery tray. Definitely use 0 AWG for upgrading the big 3. You will need 4AWG power wire to run the amp. I am in the process of ordering getting all my audio parts together. At first I was going with 2 type r's then type X's and now I just bit the bullet and spent double the $$ on a W7.
Old Sep 24, 2010 | 01:32 PM
isejay's Avatar
isejay
haha nice. wish I had a bigger budget. what do you think about this cable? http://cgi.ebay.com/KnuKonceptz-KCA-...item5adbbaddc2
Old Sep 24, 2010 | 06:34 PM
maximus54's Avatar
maximus54
I think that will do fine, I have been wanting to try that brand because they have had good reviews about their cables and are priced well too. I purchased 14 feet of Monster 1/0 AWG for $40 off amazon. Monster and Kicker are the two most preferred brands for high quality car audio cable.
Old Sep 26, 2010 | 02:23 PM
egggy's Avatar
egggy
Ya, knu makes some nice stuff
do the big 3 in 0.
Run 0 from batt to distro block, then 4 to each amp.
Joshcar
Jun 26, 2012 03:18 PM
joeykool
Apr 1, 2012 11:35 PM
The1Ghost
May 27, 2011 01:57 AM
Hermosa
Dec 2, 2003 10:40 PM
dirteedave
RX - 1st Gen (1999-2003)
Aug 7, 2003 07:08 PM
