fog light mod??
Old Apr 4, 2002 | 11:21 AM
avalance14's Avatar
avalance14
Default fog light mod??
does anyone know how to take the yellow/orange piece in the headlight out or replace it with a clear one. i want all the lenses on my is300 to be clear.
Old Sep 21, 2002 | 01:53 AM
RhoXS's Avatar
RhoXS
If the "yellow/orange piece " you refer to acts as a filter for the light, then you really do not want to remove it.
Although it looks yellow, its purpose is to remove blue light energy from the beam of light. The reason is because blue light is very readily scattered (much much more so than yellow frequencies). This is why the sky looks blue. Filtering out the blue light makes the fog lights much more effective because less light gets scattered back by the moisture in the air. As it turns out, blue is only a small percentage of the total light energy available from an incandescent bulb so you loose very little "brightness' but end up with much more effective fog lights. For these reasons, European countries used to require yellow headlamps.
In other words, if you remove the filters for cosmetic reasons, you significantly reduce the functionality and saftey of the fog lights.
Old Sep 23, 2002 | 08:50 PM
stevie's Avatar
stevie
Only in France - at least last time I was there. A yellow light is certainly less dazzling than white.
Stevie
SC3coupe
Jul 20, 2007 11:27 AM
snboarder8
Mar 5, 2003 01:08 PM
ToyLexmods
Nov 2, 2001 03:31 PM
AtlBrave
Mar 22, 2001 03:31 PM
