HELP.....1997 SC400 Stereo problems
Old Mar 30, 2009 | 04:56 PM
TBONE1904's Avatar
TBONE1904
Default HELP.....1997 SC400 Stereo problems
I have searched and have the common stereo on and working but no sound. The amp under the changer looks fine no rust and no water/corrosion. The connection under the driver rear seat looks fine no water/corrosion. I read something about a connection problem for the cell phone behind the driver side trunk panel, but didn't really see anything or know what to excatly look for. I wired up a connection for an additional amp in the trunk for my sub box in 2004. Is there a way to test the amp? The fuse under the hood for the stereo is good. Is there any other troubleshooting I can do?. I need to sell and can't without the stereo working.
Old Mar 30, 2009 | 07:40 PM
TBONE1904's Avatar
TBONE1904
bump...........
Old Mar 30, 2009 | 09:45 PM
trackball's Avatar
trackball
There are two fuses for the stereo/amp -- one is under the hood, and the other is in the left kick panel. Have you changed both?
If so, the next step will be to try swapping your amp out temporarily with a known working unit, to see if that helps.
Old Mar 31, 2009 | 09:22 AM
TBONE1904's Avatar
TBONE1904
thanks..I have checked both fuses. Can a stereo shop tell me if the amp is bad?
Old Apr 1, 2009 | 07:14 PM
TBONE1904's Avatar
TBONE1904
bump.....what do I need to buy?
Old Apr 1, 2009 | 08:46 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
unfortunately, its impossible to say what you need given the info we have... it is likely that the amp is bad, and that a replacement unit would fix your issue... however, it is also very possible that the head unit itself is bad...
you may be able to find a used set on ebay or here, but if you want a faster, better fix, ya might look into an aftermarket unit and a little bit of rewiring...
Old Apr 1, 2009 | 10:43 PM
AutoCoutureSC's Avatar
AutoCoutureSC
i vote your amp is bad
Old Apr 17, 2009 | 03:07 PM
TBONE1904's Avatar
TBONE1904
got the amp today still doesn't work........any advice?
Old Apr 18, 2009 | 06:19 AM
TBONE1904's Avatar
TBONE1904
Fixed it...the amp works.....it was the power wire I spliced to hook up the sub amp that corroded and broke. Re spliced the wire the old and new amp work!
AMP FOR SALE
4mula_J87
Jun 30, 2019 12:05 PM
4mula_J87
May 28, 2019 08:51 AM
leany
Mar 29, 2005 08:14 AM
APU6speed
Mar 24, 2005 02:07 PM
