the drivers control pannel buzzes when i press the switch the passenger side makes no noise but both windows dont come down or up presently in the up position chANGED the driver side switch pannel same results dont think its the motor because both windows are not working fuses are good mirrors and pwr lock work any sugestions?
If you can hear noise while you are pressing the button than take
the door panel apart and check "window rail"(i don't know if that's the right word for it) and plastic wheels on top and on bottom of that rail. On mine one of these wheels was broken and metal line came
off the wheel so i couldn't open/close the window.
The other one might be stuck so that's why you can't even hear
any noise.
Good luck.
