Problem (Key Fob and Gauge lights)
I just bought a 1995 Lexus SC300. First of all let me say this car is absolutely awesome. But i have two problems.
First problem: When I bought the car gave me a standard key (no key fobs) it was just a regular key. Now I assumed that was just what it came with. But it dosen't open the trunk and it cant unlock the the glove-box. So my thoughts are: Maybe its a valet key? Like they broke the master key but didn't want to pay to replace it so they just used the valet key. Does that sound right? My other question is can they make another master key for the car (key fobs and all) off the valet key?
Second Problem: The display that shows the temp in the car and the fan speed is only about half visible so the bottom half is black and the top half you can see. Is there any way to replace it? and if so can anyone give me a cost estimate?
I would appreciate any answers. Thanks for the help.
#1: Yes you can go to any lexus dealership as long as you take in proof of ownership they can cut you a new one. However if you want the wireless keyfob they have to reprogram your car to work with the key, and it costs a little too much than it should.
#2: Common problem. If you are handy with cars and electronics you can do it for about $12 i think from lexetech.com (sp?)
yup u got the valet key, lucky i got the real key + the valet.
you can order a blank key with remote off ebay and chance it working.
you will still need to go get it cut. the stealership can do it all, but it is expensive.
#2, pop dash out, start replacing bulbs. if your needles are gone you can replace those too
See that was just as easy as telling him to
SEEEEEEEEEEEEEEEEEEEAAAAAAAAAAAAAAAAAAAAARRRRRRRRRRRRRCCCCCCCCCCCCCHHHHHHHHHHHHHHHHHHh
Now let me say that the Keyless entry fobs SUCK on this car. I have to open mine and resolder the antenna once a month or so to keep it working from 40-60 feet. Otherwise, its so finicky and only chooses when to unlock the door.
Right now I have the remote button off so I just use the key.
Sewell Lexus has the best pricing for the whole set of keys. About $300.00. You can "reprogram" the remote yourself and they will give you the instructions. It is really easy.
As for the climate control, another simple fix:
http://www.lextreme.com/SC400LCD.html
http://lextreme.com/tutorial/sc_inst...guide_v2_B.pdf
Good luck
Good luck
You can get a fob from ebay...just make sure its in the same FCC range as the car.
On my SC300 I had a fob from a ES and a SC400. Programming it to your car is easy...its a hokey poky list of open this, lock that, open this again....but it works. The procedure is listed in the electronics forum.
Removing the gauge assem is also pretty simple. Again there are numerous threads.
https://www.clublexus.com/forums/sho...emoving+gauges
https://www.clublexus.com/forums/sho...d.php?t=266465
Kdash106
Nov 24, 2013 01:26 PM
