92 SC400 Nakamichi amp/speaker issue
Old Sep 18, 2006 | 07:01 PM
BBQPork's Avatar
BBQPork
Default 92 SC400 Nakamichi amp/speaker issue
Hi everyone! Noob 2 the board but am proficient in forums so I have performed searches but have not come up with anything that might assist me.
Q. I am having issues with my stereo, complete left side works fine but when I balance over to the right side the volume is very low/soft.
Balance right - fade front (low volume).
Balance right - fade back (low volume very little bass).
Balance left - fade front (loud).
Balance left - fade back (loud and has bass).
Anyone have any ideas to what my problem is? Any help would be appreciated. Thanks!
Q. I have read on the forum that there's 2 amps on the Nak system, 1 running the subs and 1 running all others and both are located under the CD changer correct?
~Brandon
Old Sep 19, 2006 | 04:00 PM
jefthim's Avatar
jefthim
Default Had the same question
I was corrected on this same question a few months ago. I was told that there is only one amp that powers all the speakers including the sub.
That sounds like a difficult problem to troubleshoot!
Old Sep 21, 2006 | 03:26 PM
BBQPork's Avatar
BBQPork
Anyone? Ideas? Fuse?
Old Sep 21, 2006 | 03:53 PM
AZ-GS300's Avatar
AZ-GS300
could be the amp
could be the speakers
could be the head unit
could be the wiring
could be just about anything.
It's very difficult to trouble shoot that type of problem, sorry.
Old Sep 21, 2006 | 04:04 PM
jefthim's Avatar
jefthim
Not a fuse...
Not sure how advanced your skills are but here is what I suggest. If you take a voltage meter and look at the voltage of what your head unit is outputting before the amp then you can have an idea if it’s the head unit or the amp. You could have a problem with either one, but I wouldn't expect that it’s both. You can compare the readings from your left and right channels to see if they are close to the same. If they are...then I would do the same thing with outputs from the amp. You should be able to locate the signal degradation somewhere.
Old Sep 22, 2006 | 02:07 PM
Durrr's Avatar
Durrr
CL Folding 25,000
sounds almost like an input from the headunit is being garbled before it makes it to the amplifier...
Old Sep 22, 2006 | 02:38 PM
BBQPork's Avatar
BBQPork
Thanks for the input everyone. I'll keep fiddling with it to see what I can find, any additional inputs welcomed!
Cwall
Feb 20, 2013 10:57 AM
ninoalfano
Sep 6, 2007 06:00 PM
bobzorunkl
Jan 11, 2006 01:04 PM
Chesapeake
Apr 16, 2002 05:50 AM
MISURA
Jun 22, 2001 05:21 AM
