Idea for car stereo, partial install already done...
Old Aug 24, 2006 | 02:58 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
Default Idea for car stereo, partial install already done...
Just finished 85% of it today... sorry no pics yet, but, here's what I'm doing:
It's a little unconventional, but I had to try it...
most of the system is normal, I have a Kicker 350.4 4 channel amp, front two channels going to front separates (stock for now, but Infinity Kappa 50.7's are in the way) and the rear two channels of the amp bridged for a single JL 13w1v2 in a ported box...
here's the odd part - the source unit... I am going to be using an Iriver PMP-120 built into the dash, with a 1/2 din Clarion 7 band EQ providing volume control and a pre-amp line driver (7 volts)
Right now, I have everything installed except the housing for the Iriver... Installing the 1/2 din Clarion unit turned out to be exceptionally easy... the bezel was a little wide, easily trimmed with a dremel, but I used the stock radio supports with new holes drilled in it, and it worked beautifully...
also, sound is amazing from the front little speakers - they handle the power nicely (who knows for how long, hope the infinity's show up soon)...
right now, as a source, I just have my little 1gb Creative MP3 player hooked up, I can't wait to get the Iriver in there... best part about all this, is cost...
The Iriver, with it's 3.8" lcd screen, and 20 gb hard drive, only cost me $200 shipped off ebay, and the Clarion EQ $65... it's like buying a in-car mp3/hard disk/lcd screen player for $265 plus a little fabrication to build a holder for the lcd screen...
I'll post pics when it's done, I just wanted to brag a little about what I accomplished today...
one more quick note - anyone have problems with the lights flickering with the beat of the turn signal when sitting at idle??? I am going to add a 1/4 farad cap back there to keep mine from doing so...
Old Aug 24, 2006 | 05:12 AM
chingpo05's Avatar
chingpo05
sounds great! keep us posted with pics and good luck
Old Aug 24, 2006 | 06:41 AM
hemogoblin's Avatar
hemogoblin
Sounds interesting. I have my iPod connected to my Alpine headunit via RCA/Mini-jack. Soon enough I may have my radio are re-done and im thinking about how I can get the iPod (wiht a headunit, with some Gauges) to just stand on something..... if that makes sense. Keep us posted, your install could give me some ideas.
Old Aug 24, 2006 | 07:06 AM
DriftGirl's Avatar
DriftGirl
sounds cool
caps are a poor 'patch'. upgrade the alt./battery or get another battery.
My SC has a harddrive based pmp as its main source as well. I dont listen to the radio, so it works fine for me. I also have a bat-cap to help out with my stereo. Look into them if you're running a high powered stereo system. They're small, lightweight and pack a major punch!
Old Aug 24, 2006 | 05:24 PM
mitsuguy's Avatar
mitsuguy
Originally Posted by Emerald
sounds cool
It's only when the turn signal is on, and is only noticeable in the lighting of the equalizer... there is no corresponding difference in sound, meaning it's a localized problem, it probably draws more current (7 volt pre-outs) than the factory unit did, so, adding a small capacitor in the local area will fix my problem for good - I had a similar issue with a 3000GT, and used the same solution... the amp is only 350 watts, and the battery is new...
the Iriver I will be using has built in fm-radio, so I get the best of both worlds...
So, now, update:
I decided against the Infinity Kappa's and Installed some Eclipse Point Source 5.25's (they were cheaper, readily available, and I liked the way they sounded in a friends car...) Quick note - easiest installation I've ever done when changing speaker diameter - 5 minutes with a dremel, some longer screws, and some silicone and all was good... I separated the tweeter from the mid (they are built to have this capability), and the tweeter mounts with the same hardware the stock tweeter did - talk about easy... I also didn't have to replace any wiring, and 75% of the stock connectors actually worked properly with the Eclipse stuff...
I will have prelim pictures later tonight / tomorrow at the latest...
Old Aug 25, 2006 | 08:23 AM
mitsuguy's Avatar
mitsuguy
Ok, here are the pictures from the midbass / tweeter install, as well as the opening for the iriver and the Clarion EQ already mounted:
here's the back of the Eclipse tweeter, sorry it's blurry, but you can see there is a screw directly in the middle of it - this mounts directly to the factory tweeter bracket:
the eclipse tweeter attached to the factory bracket, no modification needed:
here's a pic of the Eclipse midbass and crossover mounted inside the factory front cover:
I had to dremel out a slightly larger hole to make it fit from a stock 4" opening - once done, I used silicone sealant to ensure the mid was sealed in there nicely - I used bolts instead of screws in this instance - I was worried about the threading of the screws pulling out of the plastic housing:
the midbass back in the door, with the tweeter cover already installed:
a shot with the door panel back on - I am in the middle of converting my brown/tan to black and tan interior:
And a shot of the steering wheel (was originally brown, wrapped in leather) and to the right, the opening reserved for the Iriver, with the 1/2 din clarion EQ just below it...
I'll have more pictures when completed...
one other note, I was able to use mostly stock wiring, for a clean, stockish appearance on the outside... I'm not about competing or anything, and the stock wiring seriously simplifies everything...
Zoilus
Jan 25, 2015 08:10 PM
jupiterh
Jul 29, 2013 04:26 PM
Pivo154
Jan 2, 2009 07:16 AM
SPEED&ECO.
Jul 1, 2008 09:46 PM
vj604
Apr 25, 2003 02:12 PM
