Ground wire?
Old Jun 9, 2006 | 02:41 PM
reddlexus's Avatar
reddlexus
Default Ground wire?
Where is the best place to ground my amps in the trunk of a 92' SC? Thanks a lot!!!
Old Jun 9, 2006 | 03:10 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
The best place to ground any amp in any car is the frame.
Old Jun 9, 2006 | 03:15 PM
reddlexus's Avatar
reddlexus
I know that, but where as in best location on the frame? I found a spot, but it's too close to my gas tank in my opinion. Thanks!
Old Jun 9, 2006 | 03:45 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
You'll know a frame bolt when you see one. They are generally thicker than the others.
Old Jun 9, 2006 | 04:15 PM
al503's Avatar
al503
Wherever you do it, make sure that you strip any paint/primer off for the best contact possible. Also, the shorter the ground wire, the better.
Old Jun 9, 2006 | 06:43 PM
88supramki's Avatar
88supramki
gas tank ones work just fine.
Old Jun 11, 2006 | 07:14 PM
reddlexus's Avatar
reddlexus
Does anyone else have their amps grounded near the gas tank? If not, let me know where? Thanks!
Old Jun 11, 2006 | 08:20 PM
kratos's Avatar
kratos
I grounded my amps to the metal post behind the left inner fender carpet right near the power antenna ground. I made sure the paint was scraped away of course, drilled a hole and put a bolt and nut on there. Not a bad grounding spot for my 1/0 gauge.
Old Jun 12, 2006 | 11:01 AM
Lexkost's Avatar
Lexkost
Ground each amp to a different spot to insure no noise ( this is the best) but if you ground all amps at one place make sure that the larger wattage amp is on body of car first and the smaller grounds go on top of that.
1sxyrxy
50
Mar 6, 2023 08:14 PM
j_version_
Jul 12, 2009 08:51 AM
shvc1991
Sep 11, 2008 05:08 PM
white ice
Jan 5, 2006 09:23 PM
TGO112
Mar 25, 2004 08:00 AM
