Amp Q
Old Jul 18, 2005 | 05:42 PM
Rockero28's Avatar
Rockero28
Default Amp Q
Ok, so I got a brain fart guys.... If I have a 4 channel amp, and want to bridge to 1 single sub..... Can someone guide me in the wiring?? On the amp I had b4.. I was using a 2 channel(zr360) amp bridged. I used the rca out L/R and L+ and R- speaker input on the amp to the sub...
Rock
Old Jul 19, 2005 | 09:56 AM
engin_ear's Avatar
engin_ear
Everything in Moderation
To my knowledge you can't bridge 4 channels to 1 sub output, unless the amp is specifically set up for that. If your amp has dual voice coils, you can bridge each PAIR of channels to make 2 outputs, then drive each of the sub's voice coils. Check your amp's manual for the proper way to bridge it - usually you need to throw a switch in the other direction and use two specific output terminals.
Robles84
May 18, 2017 05:32 PM
bacardi
Feb 15, 2013 06:35 AM
kevin.tran
Feb 1, 2010 06:52 PM
bezee
Aug 7, 2005 06:23 PM
CoreY2K1
Aug 23, 2001 03:49 PM
