Auto open mod on sunroof?
Old Mar 6, 2005 | 07:53 PM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
Veteran: Army
Default Auto open mod on sunroof?
Does anyone know how i would go about making my moonroof switch "one touch" operation to open it? i currently have to hold down the button to open it.
further explanation, i want to be able to have it open like the dirvers side window does, goes down if you press once...
Old Mar 7, 2005 | 03:36 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
come on guys? all the mods that people do here and noone has done this??
Old Mar 7, 2005 | 04:11 PM
Blue98Gs3's Avatar
Blue98Gs3
I don't personally know how to wire this, but you could use a timed relay, so that it gives power to the moon roof opening command for however many seconds needed to open the moonroof completely.
Old Mar 7, 2005 | 07:24 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
i can wire it, thats no problem...but where do i get one fo these timed relays?
i was thinking actually of a sort fo trigger that would catch the moonroof at its fully open position and cut the power to it....hmmm...need to do more research. i have seen the one touch feature before on other cars, maybe ill pull one out of an 04 golf and see how it works...
Old Mar 13, 2005 | 05:08 PM
inovashn's Avatar
inovashn
you can get a pulse timer relay from dei at any of their vendors like best buy
Old Mar 13, 2005 | 05:12 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
ah, thanks much, il look next time im there (nearest bestbuy is 20 miles away )
but the more i look at this, the more i dont think the system will handle it, all my lights dim as it is with just the system thats in place...not sure about adding another circut with another fuse...
Old Mar 14, 2005 | 05:50 PM
omaha_lex's Avatar
omaha_lex
I may have found what you are looking for on eBay. Since I can't give you the link to the specific auction per forum rules, do a search in eBay Motors for 'Autoloc window'. It seems like a pretty nifty item, it will make your sunroof both auto open AND close (not just auto open like OEM). I hope this helps.
Old Mar 14, 2005 | 06:47 PM
ArmyofOne's Avatar
ArmyofOne
Veteran: Army
well i appreciate the thought. i have found it.
unfortunately it wil not work... the sunroof will nto auto close. it has a stopper mechanisim that stops it halfway through the closing cycle, you have to depress the button again to finish closing (saftey feature).
the more i look at it the more i think this is not going to be possible. the wiring looks too complicated, and even if i got some sort fo pressure switch, it would draw too much power. the cars electronics are pretty much maxed. it would blow the main fuse.
Old Mar 21, 2005 | 06:03 PM
inovashn's Avatar
inovashn
theres always a way to do it. after i do it next month or so(when it warms up) i'll post the process and parts.
COOLIS
Sep 30, 2024 03:51 AM
cc4sc
GX - 2nd Gen (2010-2023)
Apr 11, 2020 07:08 AM
ncsu-tc
Sep 30, 2013 12:18 PM
kqt2ktval
May 15, 2009 07:10 AM
steevr
RX - 1st Gen (1999-2003)
14
Apr 1, 2004 06:12 PM
