sc400 rear speaker wiring help!!! please help!!
Old Feb 24, 2005 | 05:44 PM
beaussc300's Avatar
beaussc300
Default sc400 rear speaker wiring help!!! please help!!
just got my nak amp sub and cd put back in. I bought the car and the orignal owner had an aftermarket amp and speakers in there
got all the factory wiring put back together (i have no idea how!) but the rear speakers had the factory wires removed and have aftermarket wires hanging from the back deck
can anyone provide the way to connect my speaker back to the system. I have no idea what i am doing in general but i did get the system to come on with the sub, tweeters, and front speakers working only beacuse the factory wires were there.
can anyone help so i dont have to pay someone to do this???
thanks!
Old Feb 24, 2005 | 05:48 PM
FireCode's Avatar
FireCode
Are the factory wires still coming out of the amp that go to the rear speakers? Surely he wouldn't have completely cut them out Check near the amp and see if you can find the cut wires. If you do then just attach new wire to the cut ends and run it to the speakers.
Old Feb 24, 2005 | 05:50 PM
beaussc300's Avatar
beaussc300
Default colors of wires you mentioned
do you know what color the wires are? there were so many and i mean many wires cut that i connect them all back together because i was experienceing a power drain on the battery
if you can please tell me the colors that would be great!!
Old Feb 24, 2005 | 06:17 PM
FireCode's Avatar
FireCode
I will try to find out for you tonight bro. Give me a couple of hours and I will go down and check! Im a bout to eat some dinna yo
Old Feb 24, 2005 | 06:31 PM
beaussc300's Avatar
beaussc300
Default thanks so much!!!
i appreciate the help!!!
Old Feb 24, 2005 | 07:33 PM
FireCode's Avatar
FireCode
Ok I am not sure here because I can see under the back deck very well. I believe the rear speaker wires are Black/yellow and White/Red and here is the reason why. The wires that run up to the front speakers are twisted together. They are like turquiose/purple and light blue/another color. The only other wires that are twisted together coming out of the stock amp are Black twisted with yellow and White twisted with red. Look at your stock amp( keep in mind I have the pioneer system but I would think that the wires would be similar) and see if you see these 2 sets of wires cut. I am sorry I can't be certain but I don't want to take apart my back interior. Hopfully someone else can chime in if they know.
Old Feb 24, 2005 | 08:00 PM
beaussc300's Avatar
beaussc300
appreciate the help
the only wires that were cut were the following
black
blue
brown out of the larger harness that connects to the plug with the green sticker above it
the other harness was completely cut off and it had the black/white and red/white wires which were the sub wires
so I only have three wires that were cut that would make sense
anyone have a suggestion as to which wire to connect rear speakers to?
Old Feb 24, 2005 | 08:06 PM
FireCode's Avatar
FireCode
Well do you see Black/ yellow and red/white twisted together? These wires are coming out of the amp that is underneatht the cd changer
Old Feb 25, 2005 | 06:42 AM
beaussc300's Avatar
beaussc300
Default its alive!
sorry man i was dead tired last night and could hardly see the computer screen much less figure wires out
IT WORKED
thanks so much for all the help!
Any chance you know where the nak amp ground wire that goes to the frame comes from??
Old Feb 25, 2005 | 10:15 AM
FireCode's Avatar
FireCode
nope. i could try to figure it out. So which wire did you end up using to get the rear speakers working?
nu4lexus
Jul 12, 2011 03:53 PM
contentryd
May 12, 2007 02:39 AM
mteele
Nov 2, 2004 12:09 AM
Millatyme
Apr 21, 2003 09:49 AM
currie
GS - 1st Gen (1993-1997)
13
Oct 14, 2002 12:18 PM
