sc400 subwoofer replacement
Old Nov 17, 2004 | 01:32 PM
liazon's Avatar
liazon
Default sc400 subwoofer replacement
i've read the threads.......not well enough it seems as i purchased a kicker compvr 10" to replace my existing 1 ohm 10" sub in my 1992 sc400 (non nakamichi) based on thread recommendations.
it doesn't fit for two reasons.......the mounting depth is excessive and the bracket on the woofer for the speaker wires are located separately on the outsides of the woofer vs tightly together just above the magnet.
i need recommendations for a subwoofer that will actually fit w/o any customization based upon someones' actual experience. please.
thanks.
Old Nov 17, 2004 | 08:37 PM
THE_CEO's Avatar
THE_CEO
Default Re: sc400 subwoofer replacement
thanks.
is the kicker speaker a free-air one? the 10" jl audio IB4 will fit perfect...if you can find one..the wires will connect with a little modification.. i posted a picture and a description of what you need to do to make it work...i had the Nak system by the way so i had a little more OEM power than you...any how here is the link...
https://www.clublexus.com/forums/sho...&highlight=IB4
good luck!!
CEO
Old Nov 26, 2015 | 07:02 AM
bobbygamer's Avatar
bobbygamer
I finally killed my Nak system also but sub looked fine still so I got a Precision Power PPI i640.5 5-channel amp it fits in the factory location I also changed out the fronts with MTX Thunder40's and put some Cerwin-vega 6.5s in the back (was a pain had to cut up deck lid with dremel) sounds great the sub is 5 ohms I had to turn up the amp to get it to thump good
fitting oversized Cerwin-vegas
farva812
Mar 22, 2014 12:24 AM
aypues
Apr 11, 2008 11:51 PM
Philly#1 Lex
Mar 24, 2004 09:49 AM
