JL audio IB4 sub install using OEM Bracket!
Old Sep 22, 2004 | 07:55 PM
THE_CEO's Avatar
THE_CEO
Default JL audio IB4 sub install using OEM Bracket!
I just finished my install of the JL audio IB4 10" sub....using the OEM bracket it too a while to figure out how to do it...i will post pics as soon as possible....im not sure if any one has used the OEM bracket...at least my searches didnt find someone...
After removing the SUB...make sure you carefully remove the OEM plugs...you will need them later...At first look the sub looks to be mounted/glued to the frame...from what i understand lexus makes it so you have a hard time putting replacement items in their fittings..anyhow you have to damage the sub and rip the cone out. Once you have taken all parts of the cone from the bracket..you are still left with the magnet..this was the hardest part....after a few quick bangs against something solid the magnet will start to shift and you will start to see the gap move further. Once you have a large enough gap use a wedge or a screw drive to force the magnet off...I had to go around the magnet in a circular motion to get it off. Now once the magnet is off the sub still will not fit...here is the hard part the 4 metal sides of the bracket which go from the top of the bracket to the magnet are weak and flimsy...they will crack with a few swift hits...when i broke one they all came off. Now i had the top portion of the bracket and the speaker drop in perfectly...dont forget to add the foam, and a little silicone or glue. Once you have the speaker in place...simply wire the OEM plugs into the 2 prongs on the speaker (+) should match up with the wire with a strip..
This solution should help those people who were hitting the gas tanks and did not want to build a enclosure for their subs.
Pics are coming later...
CEO
(Car is SC400.)
Old Sep 22, 2004 | 10:39 PM
ummagawd's Avatar
ummagawd
very nice... i did the same... thought i didn't have too hard of a time ripping apart the speaker (only cuz i couldn't stand to ruin a perfectly good sub)
although.... i must say that the stock sub amp won't do any good for the IB4
Old Sep 23, 2004 | 09:03 AM
THE_CEO's Avatar
THE_CEO
yeah, im looking for an amp that will go nicely with the IB4 what did you choose?
CEO
Old Sep 23, 2004 | 02:53 PM
THE_CEO's Avatar
THE_CEO
Crappy pic...sorry the picture was taken on camera phone at 10:00 p.m.....
CEO
Attached Thumbnails JL audio IB4 sub install using OEM Bracket!-jl-audio.jpg
Old Sep 23, 2004 | 04:45 PM
ummagawd's Avatar
ummagawd
JL e1250 its perfect and nothing else is needed to run it
Old Sep 23, 2004 | 06:02 PM
THE_CEO's Avatar
THE_CEO
do you mean the 1200?...
CEO
Old Sep 24, 2004 | 01:27 PM
soarer479's Avatar
soarer479
i also used the stock bracket when i installed me rockford fosgate in hte back deck
Old Sep 24, 2004 | 06:53 PM
ummagawd's Avatar
ummagawd
nope... i mean e1250
and now that i think about it... used the OEM bracket along with a quarter inch MDF spacer
Old Sep 26, 2004 | 10:19 AM
Suneet's Avatar
Suneet
I made my own bracket out of wood in my LS.. I'll post pics soon, the results turned out pretty good. I used rubber foam, about 1" of it underneath the spacer so that way when I bolted the entire sub and spacer down it would seal as tightly as possible without using silicone. The advantage to using wood was that I could secure the sub to the bracket/spacer using all 8 screws.
Old Sep 26, 2004 | 02:22 PM
THE_CEO's Avatar
THE_CEO
good idea!
CEO
Old Jan 29, 2006 | 05:56 AM
Mylton99's Avatar
Mylton99
Default Any luck with the amp?
CEO
Any luck with the replacement amp?
Old Jan 29, 2006 | 07:05 PM
engin_ear's Avatar
engin_ear
Everything in Moderation
Mylton, welcome to ClubLexus. Please watch out for the date of the thread you're replying to, you may get no response. Also, if threads are old, you may turn up more information by using the search function to look through all past threads for a certain topic. You might try "10IB4 amp" for this one....
CharmCtyIS
RX - 4th Gen (2016-2022)
46
Dec 11, 2024 07:50 AM
LexRuger
13
Nov 18, 2014 09:31 AM
D-MAN63
Apr 15, 2003 12:42 PM
swartzm
May 7, 2002 01:15 AM
