DVD on Nav question..
Old Mar 27, 2004 | 02:04 PM
kabrera's Avatar
kabrera
Talking DVD on Nav question..
I was just curious, with all these posts on converting composite to component, wouldn't it be just as easy to use the RGB outputs from a home dvd player to supply the signal to the Nav screen with no modifictions.
Does anyone know if this will work? same goes for a playstion with a RGB wire output. In that case all you'll need is some sort of a source selector switch.
Any opinions are appreciated on this matter..
thanks,
Old Mar 27, 2004 | 02:21 PM
LS007's Avatar
LS007
It's not component video the navigation screen uses, but analog RGB with a composite sync. You can get a converter model 9A62 by Audio Authority that converts component Y Pb Pr to RGB+composite sync. Then you could plug in sources like component video X-box adapter or Sony Playstation hi-def adapter (no resolution higher than 480) or even a home DVD player, but power and shock proofing the player become a problem.
Old Mar 28, 2004 | 04:06 PM
kabrera's Avatar
kabrera
With all these Mod kits available, what used to do the RGB video switching.. ??
Calebj
Jan 1, 2017 08:23 AM
mcgrady
Nov 13, 2007 01:41 PM
jazba
Aug 14, 2005 08:12 PM
