Accessory battery
Old Sep 5, 2022 | 09:09 AM
wfw's Avatar
wfw
Default Accessory battery
Looking under the hood today, I noticed an information sticker on the front of the hood that showed an accessory battery located in the passenger side of the trunk (2022 LC500). Further it indicated the battery was Nickel-metal hydride. I couldn't find the battery. Anyone familiar with this?
Old Sep 5, 2022 | 11:56 AM
Brinylon's Avatar
Brinylon
Can't tell you too much because mine is a hybrid but here is a photo showing the V8 and the two batteries. Look carefully for the one on the right. Not done it myself but apparently dead easy to remove the trunk trim to get to it. BTW picture was posted on another forum and in regards the fitting of a sound system so you will not see the Pioneer amp in yours.
Hope this helps you locate the second battery.
Old Sep 6, 2022 | 05:23 AM
wfw's Avatar
wfw
Brinylon,
Thanks! I will dig into my trunk and look at it. I have already looked at the main battery, but don't remember seeing the other one. Strange that there doesn't seem to be any mention of this accessory battery, given that it likely will require replacement at some time.
Old Sep 6, 2022 | 08:57 AM
can you post pic of sticker?
edit: nevermind, found it, and the battery!
Old Sep 6, 2022 | 09:26 AM
,Strange that there doesn't seem to be any mention of this accessory battery, given that it likely will require replacement at some time.
wouldn't be surprised if it lasts 20 years given reliability of toyota/lexus hybrid batteries.
Old Sep 6, 2022 | 09:56 AM
wfw's Avatar
wfw
My limited understanding of this battery chemistry is it only has about 500 to 800 recharge cycles in its life.
Old Sep 6, 2022 | 10:25 AM
maybe for an old nimh phone battery, but there's prius taxis that have been driven for hundreds of thousands of miles.
Old Sep 6, 2022 | 12:01 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Seeing the above two picts points out the difference in the stock sound system with the Pioneer amp and the second with upgraded system and the Levinson amp.
Old Sep 6, 2022 | 12:45 PM
wfw's Avatar
wfw
Bit,
Good point. That's probably why I can't find anything on this accessory battery. Because it isn't a maintenance/wearout item like the main battery.
Old Sep 6, 2022 | 01:25 PM
Brinylon's Avatar
Brinylon
Bit,
It does seem that a "normal" Ni MH battery has a limited number of recharge cycles, but if push ever came to shove, I guess it could be replaced given it's a Panasonic unit. What I don't understand is why these secondary batteries are hardly worthy of mention and not just by Lexus, I had the same in my Jags where there was practically zero reference to a second battery and again were tucked away out of sight. It makes you wonder if there is some controlled charging regime of this battery that extends or ensures a long life, particularly when other indications would suggest they have about a 5-year life span. Mine hit five years of age this June, and so far so good.
Old Sep 6, 2022 | 02:25 PM
wfw's Avatar
wfw
Brinylon,
It is a little perplexing there is no mention of it anywhere I have looked.
Old Sep 6, 2022 | 04:09 PM
the pioneer amp looks tiny.
lancecov
ES - 7th Gen (2019-2025)
Apr 13, 2019 07:30 AM
new_berlin
HS 250h Model (2010-2012)
Dec 18, 2017 10:13 AM
lexuspower
Sep 19, 2013 12:54 PM
Durrby
Jun 14, 2011 08:20 PM
sc400
Maintenance
Sep 3, 2003 04:11 PM
