Missing jack?
Old May 20, 2022 | 12:03 PM
  #31
DRGibbons's Avatar
DRGibbons
I second redhot47fl's email. Since the vehicle has run-flats OEM no jack and accessories are included. I have a 2018 Coupe.
Old May 21, 2022 | 04:06 AM
  #32
Brinylon's Avatar
Brinylon
Curiously, even with run flats, mine came with a jack, a handle and a screwdriver. Seems odd to have a tray and not fill it with what it was made for. BTW, 2017 coupe and a UK model.
Old May 21, 2022 | 10:32 AM
  #33
dknyov's Avatar
dknyov
2021 Vert US model, Lexus cheap out for US folks.
Old May 21, 2022 | 10:48 AM
  #34
Brinylon's Avatar
Brinylon
Usually the other way round if you were to ask me but hey ho I'm not complaining
Old May 21, 2022 | 11:12 AM
  #35
dknyov's Avatar
dknyov
I am curious if those jack can hold up our LC? I am really sure the LC is more heavier than the RX 350.
Old May 21, 2022 | 11:17 AM
  #36
Brinylon's Avatar
Brinylon
Given it's a 2 ton car it's weighty but the jack is also fairly meaty. If I were ever to lift the car, then I would be using something far more appropriate. Having said that, scissors jacks might look feeble but are far stronger than their looks would suggest.
Old May 21, 2022 | 11:26 AM
  #37
dknyov's Avatar
dknyov
I bought 3 ton jack to change my set of tires, better safe than sorry.
Old May 21, 2022 | 03:17 PM
  #38
azmojo's Avatar
azmojo
When I bought my used '19 I noted the missing jack/etc and the dealer confirmed it didn't come with any. I suspect that in some countries like the UK they may be required to provide a jack by law.
Old May 21, 2022 | 03:23 PM
  #39
DRGibbons's Avatar
DRGibbons
Let's be a bit logical here folks. Whether you have run flats or not, what are you going to replace the flat tire with once you jack it up and remove the wheel???
Old May 21, 2022 | 11:06 PM
  #40
Brinylon's Avatar
Brinylon
This of course is true but I guess some might wish to work on the brakes, new pads or whatever albeit I think a scissor jack is normally only there to change out a wheel/tire. Not something I will be putting to the test and I would guess the same for most LC owners.
BTW here is a hydraulic press demolishing various jacks including (for some) our errant scissor jack. Word of caution here, this YT channel can become addictive :
Old May 24, 2022 | 01:12 PM
  #41
azmojo's Avatar
azmojo
Easy. You use it to remove the tire and then walk it to the nearest tire store, get it fixed, come back and reinstall it.
Old Jun 23, 2022 | 07:21 PM
  #42
Default missing lug wrench?
i noticed in my trunk there's no tire lug nut wrench. should it be there?
Old Jun 23, 2022 | 07:47 PM
  #43
flowrider's Avatar
flowrider
Veteran: Air Force
https://www.clublexus.com/forums/lc-...ng-a-jack.html
https://www.clublexus.com/forums/lc-...-and-jack.html
Old Jun 23, 2022 | 08:33 PM
  #44
thank you sickpuppy!
merged these thread and stickied.
Old Jun 23, 2022 | 10:48 PM
  #45
flowrider's Avatar
flowrider
Veteran: Air Force
https://www.clublexus.com/forums/lc-...cessories.html
https://www.clublexus.com/forums/lc-...unk-tools.html
There's more!
