Exhaust Valve Controller
Old Feb 17, 2018 | 08:21 AM
LCInfrared's Avatar
LCInfrared
Default Exhaust Valve Controller
Hi, my first post as a new member. I've got a fully optioned LC on order and am looking for info on exhaust baffle valve controller. Anyone already have a shot at this?
If not, sharing a diagram of the fuse box would be a good start
Old Feb 17, 2018 | 08:51 AM
Craig B's Avatar
Craig B
I would think if you would disable it, it would trip a check engine light...
Old Feb 17, 2018 | 08:59 AM
LCInfrared's Avatar
LCInfrared
That would be part of the test; Removing the fuse for permanent open mode is not an option I'm looking for, would prefer a remote module that could control it, much like one that is sold for the Camaro ZL1 and corvette.
Old Feb 17, 2018 | 11:10 AM
flowrider's Avatar
flowrider
Veteran: Air Force
Not to change the subject, but Forum Sponsor PPE Engineering makes an exhaust system for the ISF, RCF and GSF with vacuum controlled valves. My installation also includes an override switch on the dash that allows me to open and close the valves at will.
https://www.clublexus.com/forums/is-...e-muffler.html
Lou
Old Mar 12, 2018 | 10:12 AM
TCB1977's Avatar
TCB1977
I don't know of any valve controller for the LC, but if you should want them to ALWAYS be open, then on the passenger side under the hood just block off the vacuum line that opens it. It is not much louder but you now don't get that extra surge of open flap power and sound at 3500 RPM as its always available, and no engine light. Enjoy
Old Mar 12, 2018 | 10:17 AM
LCInfrared's Avatar
LCInfrared
Thanks but there are in fact two valve controlers mounted onto the flaps that are located just behind the rear silencer. They are electrically operated. My goal is to gain the option to open them up full at the press of a button. The remote controller will not trigger any engine lights and it has been used in several exotics for years without any issues.
Edit: Based on my research, the vacuum tube you are referencing controls the (noise) flap for the cabin not the exhaust itself, which is electrically controlled by the ECU.
Old Mar 12, 2018 | 03:24 PM
Hoppean's Avatar
Hoppean
I'd be interested in getting one if the remote indeed turns out to be compatible. Thank you for keeping us updated.
Old Mar 12, 2018 | 03:28 PM
LCInfrared's Avatar
LCInfrared
Of course. If you can locate a fuse that is dedicated for the exhaust baffle control, it would certainly help speed up the process. There are several fuse boxes on the LC and the application of each fuse should be marked under the covers. Cheers!
Old Apr 1, 2018 | 09:43 AM
LCInfrared's Avatar
LCInfrared
After much research and electrical diagram verifications, it's clear now that one cannot control the exhaust flaps through the use of a remote module. There are several signal inputs coming from both the drive modes and the ECU algorithms, so they are not controled by a single source.
FYI: If anyone is interested I have the the complete electrical diagrams for the LC, including detailed fuse box lists, MIL codes, acronyms, code abbreviations, network ground points, etc...Just PM me.
diggdyone
RC F (2015-present)
17
Apr 26, 2020 01:01 PM
topguy573
IS F (2008-2014)
Aug 15, 2018 01:39 PM
rns
NX - 1st Gen (2015-2021)
Mar 13, 2016 02:07 PM
