Raw Gas smell
Old Nov 15, 2024 | 07:00 PM
tecman's Avatar
tecman
Originally Posted by Veight
Keep a fire extinguisher with you in the car until you determine what it is.
Standard equipment in my cars
Amazon Amazon
Old Nov 21, 2024 | 08:11 AM
NickL's Avatar
NickL
Originally Posted by np20412
It's happening right now severely so I stopped in at the dealership (different than earlier) to have them document it. The initial suggestion is to leave it parked outside a few days to see if it'll "go away" as the service Mgr said he's had that happen with a couple other models.
I'll keep it parked outside until Tuesday without driving it and then give it some drives and see what happens, then I have an appt on Thursday.
What’s the status and update on this?
Old Nov 21, 2024 | 08:15 AM
np20412's Avatar
np20412
I let it sit from Friday evening - Tuesday afternoon then took it for a spirited 20 min drive, no smells. I did the same thing yesterday, one drive to pick up the kids and another to grab dinner, no smells.
The real test will come today and tomorrow after I fill up the tank and drive it in the exact conditions in which the smell previously occurred. Will update, but hopefully things have worked themselves out.
My service advisor said he spoke to the master tech who said it's possible a small amount of fuel got into the evap canister, and constantly driving it around once it was in there allowed the canister to continue to build vapors which would then prevent the fuel that got in there from being able to evaporate out, resulting in the smell. A few days to sit without driving may have allowed the fuel in the canister to dry up thereby eliminating the smell.
I cancelled my appt for today and rescheduled it for Dec. 6. I think that is enough time with the holiday week coming up to drive it in all manner of circumstances to see if the smell is reproduced. If it is, I'll take it in. If not, all's well that ends well I suppose.
Old Nov 21, 2024 | 09:20 AM
rcubed3r's Avatar
rcubed3r
5th Gear
Something that I do not see mentioned is that this kind of issue can be caused by topping off your gas tank when you fill up. The gas can overflow into the evap and soak it and eventually cause it to fail. It's not supposed to happen, but it does.
When filling up stop once the handle pops on the nozzle from the gas pump. Don't try to get a few more ounces in.
Old Nov 21, 2024 | 09:21 AM
np20412's Avatar
np20412
Absolutely. I never top off. It's possible the pump auto stop was not functioning properly though and resulted in a bit more fuel than normal going in
Old Nov 21, 2024 | 12:39 PM
flowrider's Avatar
flowrider
Veteran: Air Force
I Top Off all the time - Never an issue
Lou
Old Nov 21, 2024 | 06:56 PM
np20412's Avatar
np20412
Filled the tank and drove about 65 miles today. No smells yet! 👍🏾
Old Nov 25, 2024 | 11:04 AM
np20412's Avatar
np20412
well this problem seems to have gone away on its own for me. I cancelled my dealer appt. Hopefully it doesn't repeat itself, or if it does, at least the car throws a code so I don't have to play whack a mole with the service department to diagnose.
Old Dec 9, 2024 | 03:45 PM
np20412's Avatar
np20412
Well...it got over 80 degrees today for the first time in a while, and I drove 120 miles, and I filled up the tank on the way home from nearly empty (no top off, stopped at first click and it took about 18.5 gal). Got home and the gas smell has returned. 1 hour after parking I went in the garage to grab my sockets and it hit me full force.
At this point since the car isn't throwing a code, there is no noticeable loss of power, I am just going to leave it be over winter and see what happens come spring when temps get back reliably around 80 to see if still happening, at which I'll take it to the dealership. I am questioning if there is a bit of a rougher than normal idle going on though, sometimes I can feel pulsing in the seat and hear the engine tone changing with the pulsing while the car is idling in P or in D with my foot on the brake, but I have no idea if what I'm feeling is something new or just normal.
Old Dec 9, 2024 | 11:45 PM
2ksoftail's Avatar
2ksoftail
Man that really sucks. Don't understand why it comes and goes on what appears to be 'random' times. Look on the bright side, at least you are on the Lexus Dime.
R Z
Sep 5, 2015 09:07 AM
OCLEX03
Jul 29, 2010 09:37 PM
ROBGS300
GS - 1st Gen (1993-1997)
Jan 7, 2009 05:35 PM
ayonnebay
May 29, 2008 07:26 AM
breakb
Mar 22, 2008 01:51 PM
