Brake Dust
I fitted Power Stop Z23 to my 2024, Z232063 & Z232062
They aren't listed for the 24 but the only thing I found was a round hole in the power stop backing plate rear pads instead of an oval one on the factory pads to accept a spring so I swapped them over
Very happy with them, have them on my MK V Supra as well
What year is your LC? There’s a TSB on this and you could get it replaced by the dealer to the nonperformance pads that have less dust and no squeal. The TSB only goes up to 2021 model but I assume if you show it to your dealer, it would be valid for later model year as well.
How many miles you got on it? I know I did it on my GSF at 15k miles because I couldn’t handle the squeals anymore. The non performance pads are less grabby but a lot less dust and no noise. I said a lot less dust but still some dust.
I’m less than 3k miles on my ‘24 LC on original pads. The dust is horrific and squeal at times. I find that the dust is not a win-able battle. I clean the wheels, rotors get wet, go take a short drive around the block to clear that, come back with dusty rims again. Fawwwkkkk… I kind of stop looking now. And with the black wheels, it’s not that noticeable.
The TSB stopped with MY2021 because the LC500 base and touring package no longer come with the performance pads; they switched to the lower performing pads. The Sport and Dynamic Handling Packages still have the performance pads and are not subject to the TSB.
Lou
Lou
