My exhaust tip mod
I just did a small addition to the stock exhaust tips. I hope it helps. Check it out:
https://www.youtube.com/watch?v=wTFn0CW3VvI
Did adding these tips change your exhaust note or anything?
It's definitely a much better look than the 'fake' exhaust openings. Don't understand why so many makers do this. Maybe it's so that they don't have to properly align the exhaust to not look crooked at the exit/opening?
I may try this mod out!
I can't agree more. I respect the need to make the LC your own. Sticking four round pipe out the back of a piece of art seems counterintuitive. It is like you need to prove something. You might be missing the point. I have owned other cars and trucks in which this is more fitting.
LC 500 in my opinion not one of them.
I fully support you making your LC yours.
If it looks good to you that is the most important part!
Thank you everyone. Here is the link to ebay, I believe these are on Amazon as well but for a tad more money. I did have to cut off a little for the inside tips and I took out the tabs for the fitment. I shaved down the bolts only so they don't stick out as much, not necessary and I just used the bolts to tighten. It requires a little back and forth on each side to get them tight and straight. The angle on the picture is a little off but I fixed it. This doesn't change the sound at all. 3" tips I don't will fit inside but if you wanted them to stay recessed they should work. I'd like ovals and I saw someone had them on here but I can't find a link.
https://www.ebay.com/itm/384953738985
