USB port
Old Jul 17, 2025 | 02:03 PM
verm's Avatar
verm
2nd gear
Default USB port
I have a 2022 LC500 and recently the USB ports have died. no phone hook ups or charging. tried different leads and no luck.
has anyone had this issue and if so how was it fixed?
thanks
Old Jul 17, 2025 | 02:23 PM
tecman's Avatar
tecman
The fuse that controls that should be in the driver side fuse box under the dash to the far left. Check the two fuses marked with red in the picture.
Old Jul 19, 2025 | 07:09 AM
verm's Avatar
verm
2nd gear
tacman, thanks for the info.
both fuse's were good.
i guess a trip to the dealer is in order.
thanks again for the tip.
chris
Old Mar 27, 2026 | 08:29 AM
Shermang's Avatar
Shermang
What was the solution for this? Having the same issue on my 2018
Old Mar 27, 2026 | 01:35 PM
Korbek's Avatar
Korbek
The OP has only posted twice and both were in this thread so a response may not come. But it's worth a tag just in case @verm
That said, if you've checked the fuses mentioned above and both are good, you'll likely need to take a trip to the dealer for diagnosis.
My wild *** guess is corrosion in the connections for the USB ports (internal connections for the wire contacts, not the port itself). That would explain lack of current in the port without a bad fuse.
Old Mar 27, 2026 | 01:37 PM
Shermang's Avatar
Shermang
Originally Posted by Korbek
The OP has only posted twice and both were in this thread so a response may not come. But it's worth a tav just in case @verm
damn..I hate when a issue never has a resolution comment lol.
Old Mar 27, 2026 | 01:38 PM
Korbek's Avatar
Korbek
Added some add'l info above based on my rudimentary knowledge of electronics (aka cleaning NES cartridge contacts with isopropyl alcohol).
RLM
RX - 4th Gen (2016-2022)
Sep 27, 2023 11:52 AM
Janbillc
Aug 14, 2021 11:48 AM
Fjaw
NX - 1st Gen (2015-2021)
Apr 26, 2019 06:50 AM
VA75067
Mar 8, 2019 10:45 AM
AustinHusk
May 6, 2016 10:05 AM
