USB A to USB C Apple Carplay
Old Jun 26, 2025 | 07:46 PM
jennypenny's Avatar
jennypenny
Default USB A to USB C Apple Carplay
Hi Guys,
I got myself an iPhone 16 Pro and it has a USB input, I cannot seem to get it to work with the LC
Previously, the USB A (car) is connected to my lightning cable (also USB A), works (but the GPS is not so accurate)
Now, the USB A (car) is connect to my USB A to USB C cable, my iPhone 16 can charge but will not launch Apple CarPlay
Any advice?
Old Jun 27, 2025 | 05:34 AM
tecman's Avatar
tecman
Make sure you're using a proper data cable—not just a charging-only one. Also, the bottom USB port seems to be the only one that works with CarPlay in the LC based on my experience and what others have reported.
Old Jun 28, 2025 | 08:30 AM
craftyg's Avatar
craftyg
2nd gear
Default Carplay
This is what I use...
motorola ma1 carplay, if you Google it you will see it everywhere. I got mine from Amazon. It makes it all wireless and all the extra controls work perfectly.
Old Jun 28, 2025 | 09:30 AM
dmanb2b's Avatar
dmanb2b
Wireless BT adapter...there are plenty on amazon. I use a carlinkit
Old Jun 30, 2025 | 01:07 AM
jennypenny's Avatar
jennypenny
I tried the Carlinkit 5.0, it doesnt work with the LC500
jennypenny's Avatar
jennypenny
Not available in Singapore, unfortunately
Old Jun 30, 2025 | 03:59 AM
breplica's Avatar
breplica
Originally Posted by jennypenny
Hi Guys,
Any advice?
Hello friend, I am also from Singapore. I am using a USB C iphone 15 pro in my car (wired USB A to USB C to my phone) and it's worked flawlessly for nearly 2 years. I would check to make sure I am using the correct port in the car and if so, try swapping to another USB A to C cable, some cables can be finicky with data transfer. If you need some in person help or to see it working in my car, you're welcome to DM me and I can show it to you in person. Cheers
Old Jun 30, 2025 | 12:51 PM
flowrider's Avatar
flowrider
Veteran: Air Force
For a brief time, I used a Carlinkit 4.0 on my LC. Don't see why Carlinkit 5.0 would not work I ultimately switched to an Ottocast Play2Video. The reason for the switch was because none of the Carlinkit's three resolutionsfilled the LC screen properly The Ottocast units' resolution conforms to the LC screen just fine
Lou
Old Jun 30, 2025 | 05:25 PM
dmanb2b's Avatar
dmanb2b
Lou
Yup, I use a 3.0. Works fine, just like wired with the exception of the start-up/connection screen, which disappears in a few seconds
Old Jul 1, 2025 | 07:07 PM
jennypenny's Avatar
jennypenny
Thanks guys,
I managed to get CarPlay working with a USB C now
I changed a brand new Anker cable and it works
Old Jul 1, 2025 | 08:45 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Maybe go up and edit your original post
Lou
Old Jul 2, 2025 | 06:58 AM
Thanks guys,
well done.
this wireless carplay adapter has newer tech and is much faster than older ones. i have one in each car and it works flawlessly.
https://a.co/d/gENzZlm
Soulrebel53
NX - 1st Gen (2015-2021)
Apr 29, 2025 04:36 PM
garagemonk
ES - 7th Gen (2019-2025)
Jun 15, 2024 12:05 PM
msyost
Nov 1, 2021 11:56 PM
Caydoc
CT 200h Model (2011-2017)
Sep 23, 2013 03:39 PM
