TPMS Advice Needed
Old Mar 21, 2025 | 07:02 PM
2025LC500's Avatar
2025LC500
Default TPMS Advice Needed
Hi, so I recently replaced the tires and wheels and I’ve attempted to use the change wheel set reset feature in the car and the TPMS sensors just aren’t picking up any advice?
Old Mar 21, 2025 | 07:09 PM
NickL's Avatar
NickL
Which tpms you’re using?
And how long did you drive the car with the car trying to read the new sensors.
Old Mar 21, 2025 | 07:19 PM
NickL's Avatar
NickL
See post #18. I’m using the OEM tpms for the LC500. They’re expensive but they guaranteed to work.
https://www.clublexus.com/forums/lc-...l#post11817099
Old Mar 21, 2025 | 08:43 PM
2025LC500's Avatar
2025LC500
I ordered from TPMS.com. I have had three drives each was at least 20-30 minutes. I thought surely long enough to make a sync.
Old Mar 21, 2025 | 08:46 PM
2025LC500's Avatar
2025LC500
and thanks for the reply. Your blue LC is amazing. I'm stressed about this TPMS situation, I don't want to have to have these wheels/tires remounted. I know something is gonna get scratched every F time I go.
Old Mar 21, 2025 | 11:22 PM
lexo98's Avatar
lexo98
Need the brand and part #
Old Mar 22, 2025 | 03:49 AM
LC2022's Avatar
LC2022
10th Gear
With respect to resetting the TPMS, below are the steps that I used and so far no issues with both OEM and non-OEM TPMSs. I just swapped out of summer into the all seasons.
Start the engine and keep the vehicle in PARK.
  1. Select “Settings” (gear icon) using the steering wheel LEFT/RIGHT buttons.
  2. Select “Vehicles Settings” then press and hold the center OK button.
  3. Select “TPWS” (Tire Pressure Warning System), then select “Change Wheel.”
  4. Press and hold the OK button until the TPMS warning light flashes 3 times.
  5. Drive the vehicle for 10-30 minutes, staying above 25mph when possible, and the light will turn off once the sensors are registered. Note: Refrain from reversing and driving in heavy traffic during the relearn process.
    Park and allow the tires to cool for at least 3 hours.
After the light has turned off, place the vehicle in PARK and select “Settings” again.
  1. Select “Vehicle Settings” then press and hold the OK button.
  2. Select “TPWS”, then select “Set Pressure.”
  3. Press and hold the OK button until the TPMS warning light flashes 3 times.
  4. Drive the vehicle for 10-30 minutes, staying above 25mph when possible, and the light will turn off once the current tire pressures values are accepted
Old Mar 22, 2025 | 06:42 AM
2025LC500's Avatar
2025LC500
Order Details:
Code Item Qty Price Grand Total GGL-TSS-SET-7242 TPMS Sensor set for 2024 Lexus LC500 42607-48010
2025LC500's Avatar
2025LC500
thanks. I’m going to try again today.
Old Mar 22, 2025 | 06:47 AM
NickL's Avatar
NickL
Get up to Highway speed.
Old Mar 22, 2025 | 06:49 AM
2025LC500's Avatar
2025LC500
will give it a shot. Thanks NickL
Old Mar 22, 2025 | 07:15 AM
lexo98's Avatar
lexo98
Order Details:
Thats not the right sensor for your year.
https://www.dillvalves.com/tpms-look...C&yr=2024%20(R)
Old Mar 25, 2025 | 03:10 PM
DVSSN's Avatar
DVSSN
Was your TPMS issue resolved after the reset?
Old Mar 25, 2025 | 03:49 PM
2025LC500's Avatar
2025LC500
ok. So I drove for an hour last night and just as I was pulling into the garage they paired up and are working correctly.
this is also after ordering new OEM sensors from Lexus parts now .com. So, if any needs OEM sensors I guess I’ll have some for sale!
thanks NickL.
Old Mar 25, 2025 | 04:54 PM
NickL's Avatar
NickL
That’s great news. I would return or cancel the OEM tpms as you will have a hard time getting back what you paid for.
