TPMS Advice Needed
Old Mar 26, 2025 | 08:57 AM
DVSSN's Avatar
DVSSN
Great news! On my 2020 GS F I tried aftermarket sensors and they would not pair up. I ended up ordering OEM's and had to have the aftermarket set of wheels dismounted and remounted to swap sensors.
Glad you were able to resolve
Old Aug 9, 2025 | 07:10 AM
np20412's Avatar
np20412
FYI for anyone else reading this thread. I bought the same sensors as @2025LC500 from tpms.com for my 2024 and at first they would not pair up at all. I drove upwards of one hour at times, over 60 miles at highway speed. Gave up and bought his set of OEM sensors and lo and behold after 250 miles cumulative driving across probably close to 10 trips, the sensors finally registered and displayed. So now I have an extra set of OEM sensors lol.
So basically, don't give up right away, give it at least a full tank of gas to see if they'll pair up.
Old Aug 9, 2025 | 11:05 AM
lexo98's Avatar
lexo98
It looks like there are 2 different options in the setting screen. When your installing new sensors you need to go the change wheels section. After the sensor light turns off you need to go back hit set pressures.
Old Aug 9, 2025 | 11:27 AM
np20412's Avatar
np20412
Right. Getting the sensor light to turn off is the problematic part of this process!
When you hit "change wheels set" the light will blink 3x slowly then it will rapid blink for 1 minute, then it will be on solid. This is when you need to do the "10-30 minutes of driving over 25mph" to attempt to get it to pair and register, at which point it will turn off when it does (eventually lol). Then you let the tires cool, fill them to where you want them, and then do "set pressure" to baseline the system at your pressures.
Old Aug 9, 2025 | 01:10 PM
lexo98's Avatar
lexo98
I would suggest not turning the car off once you put it in the tire change mode. Will also go quicker if you have access to a tpms scan tool
Old Aug 9, 2025 | 01:45 PM
np20412's Avatar
np20412
Yeah not turning the car off would be ideal but I had already driven 60 miles lol. Anyway it worked, just took quite a long time. Scan tool would help but was trying to do it without spending any money since the car should be able to learn the sensors. Just annoying that the process is not transparent at all and quite finicky if doing it this way.
I do wonder if OEM sensors would have paired quicker
Old Aug 9, 2025 | 04:14 PM
NickL's Avatar
NickL
The OEM sensors I got from the dealer registered within 15mins of a drive.
If it takes longer to register on non-OEM sensors, I wonder how accurate and how fast they update the reading.
Old Aug 9, 2025 | 04:17 PM
np20412's Avatar
np20412
They're accurate now that they paired. They read 37 as soon as they paired and that's what the tire was when I got home this morning. Just now updated all tires to 33 cold pressure and drove down the block, all tires reading 33 psi.
bswhitener
Jun 15, 2023 07:18 PM
10lexISR6
Apr 19, 2016 04:24 PM
SNiiP3R
Jan 9, 2015 03:41 AM
armadadd
Sep 26, 2013 12:21 PM
BoostAddct
Jun 19, 2007 06:43 AM
