Dumb mistake....fuel
Old Mar 16, 2024 | 09:47 PM
econlexus's Avatar
econlexus
1st Gear
Default Dumb mistake....fuel
First time poster here. I've owned my 2019 LC500 for about 6 months and went to fill up this evening only to realize after completely filling the car that I put in 88 octane non-ethanol fuel. I immediately remembered that the car needs a minimum octane of 91, and now I'm worried that the car might (even if unlikely) get some sort of damage.
My question is this - should I....
a) drive it carefully and refill with 93 octane as soon as possible (3/4 tank, then again and again and again)?
b) somehow figure out how to drain the fuel from the car (remove fuel pump, siphon, etc.)
c) buy a high quality (is there one?) octane booster that would add 3 levels (30 points) of octane and hope it doesn't have any adverse effects on plugs, etc.
d) anything else?
Thanks all
Old Mar 16, 2024 | 09:51 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
You will be just fine running it out, the ECU will adapt. You might get slightly less power and mpg. Id personally avoid going full throttle a lot out of an abundance of caution but you should see no damage.
At half tank I’d top off with premium and not worry about it after that.
Old Mar 17, 2024 | 12:28 AM
NiceCars's Avatar
NiceCars
The non ethanol part is good
Old Mar 17, 2024 | 01:25 AM
jbuffett's Avatar
jbuffett
You'll be fine either way, but if I were you I'd head to any auto store and get a bottle of octane booster. The car will detune itself to reduce knocking, but octane booster isn't that expensive so why have the car detune itself just to change timing again when you're back on premium.
Old Mar 17, 2024 | 05:34 AM
NiceCars's Avatar
NiceCars
I’d think twice about doing this as it may void your warranty.Furthermore, the “points” increase referred to by boosters are in tenths, they are not full points.
Old Mar 17, 2024 | 05:36 AM
Barncobob's Avatar
Barncobob
id drive 1/4 tanks worth, refuel with premium and keep doing that 1/4 tank for awhile to dilute the other..instaed of going cold turkey at end.
Old Mar 17, 2024 | 06:44 AM
Cooker883's Avatar
Cooker883
There’s no way regular gas is going to do any damage. Just pretend it never happened!
Old Mar 17, 2024 | 08:23 AM
355F1's Avatar
355F1
I love these posts.
Your car is fine. Your car will be fine. There will be NO damage or long-term effects.
Old Mar 17, 2024 | 08:35 AM
StuM's Avatar
StuM
Not going to hurt your car. Just drive easily. ECU will retard the spark if it detects pinging and you’ll lose a bit of power, but you’ll probably not notice. I’d stay away from additives; some are suspected to foul cat’s and O2 sensors. No harm, no foul. Now…go say three “Hail Lexus”, beat yourself with a birch branch and have a pint for St. Pat’s Day. BTW - using a lower octane fuel may be a slightly bigger issue with a blown engine (S/C or Turbo), but even then it can be worked through by being gentle with the go-peddle and topping off with higher octane as soon as practical.
Old Mar 17, 2024 | 04:20 PM
IS_250's Avatar
IS_250
not going to hurt anything, But i wouldnt be out there hammering the car full throttle. Burn it off and refill with Premium again once its empty.
Old Mar 17, 2024 | 09:37 PM
flowrider's Avatar
flowrider
Veteran: Air Force
I've been Using Lucas Octain Booster for the past three years in my LC. With the crap gas we get in AZ it raised my KCLV from 19 to 23. I can't see it voiding any warranty
Old Mar 17, 2024 | 09:43 PM
NiceCars's Avatar
NiceCars
Many vehicle manufacturers do not recommend or allow additives. Check you warranty book. FYI octane booster leaves a telltale orange coating on the spark plugs, and the extra points they claim in octane # improvement is actually in tenths, not full points so the gain is minimal.
Old Mar 18, 2024 | 08:22 AM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Did you not see my increase in KCLV The results are indeed real, at least that's my experience with the Lucas product I believe the orange coating you mention occurs when the user doesn't follow instructions and puts in too much of the product.
As far as manufacturers having a prohibition against the use of octane boosters, I know of no such case
https://driving.ca/features/maintena...ctane-boosters
Old Mar 18, 2024 | 12:39 PM
NiceCars's Avatar
NiceCars
The orange coating occurs with use/over time even at the recommended usage.
Try sending Lucas an email and ask if using their octane booster may affect a new vehicle's warranty and see what they say...my guess it will be something like what I advised you as I've already done so with another well respected brand. Read your vehicles warranty and you'll see if there's any verbiage re fuel additives, it is a common disclaimer. Yours is an '18 so it's kind of a moot point to begin with but something to keep in mind for your next/other vehicles still under warranty. There was a somewhat recent law where vehicle manufactures cannot just void your warranty for using additives but if they show it did cause an issue like premature wear, corrosive coatings, dilution issues, etc. etc. they can. Most do not advocate their usage.
Old Mar 18, 2024 | 12:43 PM
Dukeaudio's Avatar
Dukeaudio
For verts in HI and PR, EFI added at 6mos/5k mi mx.
