Programming TPMS display in multi info
If its weather related, all 4 tires will read the same.. But if you have a slow leak, nail or ONE damaged tire.. The gauge will help you identify the tire so you can air it up or maybe put on the spare.. This will prevent a blow out before going on the drive itself, doesn't matter if its streets or fwy.
The TPMS light did its job correctly - unfortunately it was ignored.. the light itself saved me a few times before my 5am drives..
Nobody likes a blowout at 5am at 75 mph..
sample of digital tire gauge
Joe Z
Typically when programmed ; ID1 through 4 should correspond in this order - FL, FR, RR, LR perspectively.
But I've seen that order get mixed up if a wheel rotation gets performed, new sensor programmed,etc.
So yeah you'll have to keep them in that position as labeled, since this older TPMS system doesn't update wheel positions like newer systems.
Do I need the cable if I know the codes ??
Also, will the PSI data just appear on the iPhone app wirelessly?
Joe Z
Joe Z
I'd have to pull up the FSM on Monday to get exact system operation but it's essentially a handshake every key cycle and I forget what the refresh rate is from the module to sensor monitoring. I want to say every 5-10 minutes in my "tire light" experience, PIDs might refresh much faster however.
As far as my PID screenshot, you'll just need a OBD Fusion compatible OBD2 dongle that's either wifi/Bluetooth. Like mentioned prior, you need to purchase the add-on for these features/PIDs.
I primarily use the app to monitor kclv, knock sum, temps, clearing/reading codes though.
It's a VERY good app IMO but limited by the age of the ISF development processor speeds.
Datalogging tends to duplicate PIDs under 100ms refresh rate.
(My car is currently torn down over winter, else I'd get better info for you)
From what I understand, OBDLink and OBDFusion are the same developer, so it doesn't make sense one would work and the other not work, but in the ScanTool forums, members say PIDs can change MY to MY or even with engine options in the same MY. That sort of makes sense, but I'm still a lot less than happy. It was nice to see KCLV at 24.8 though.
Displays Tyre pressue and temp all the time. It has helped me out once when one of my tires got slashed while driving on the motorway. Was a real life saver as the alaram rang well before I realised I was loosing pressure.
