Transmission mount upgrade (KEIN)
#106
i didn't do the install, a shop did. and yea if i put my music at 30 i can barely hear it lmao. im returning to them tomorrow morning but its a 2 hours drive from my place. is it still safe to drive?
#108
I stumbled upon this..
https://www.ebay.com/itm/KEIN-Transm...UAAOSwQ5pdFLdp
Anyone seen or purchased one? I just ordered mine since it looks overall better then the oem design.
This is the correct mount that you ordered correct? Even though is doesn't say anything specific for the ISF?
Thx
#109
MileHIFcar (11-04-20)
#110
Ok, Thanks
#111
Thankss
#112
Tech Info Resource
Interested if the OEM trans mount parts shown in photo posted, can also be installed in same year non IS F vehicle (IS 350 RWD), without issue?
Is part 12392-38020 (upper rear trans mount isolator 2015-2020 RC F 5.0 engine), a higher durometer than the suggested OEM part 2371-31070 - Automatic trans mount (06 - 2015 IS 350 base / F Sport), similar with installing the front lower control arm bushings from 2015-2020 RC F ( 48075-24010 Right / 0 offset & 48076-24010 Left / 0 offset), into base IS 350 RWD vehicle?
#115
Joe Z,
#116
#117
That idk but what I can tell you is even when that mount is new it’s soft and can be compressed by hand. I tried the Megan racing trans mount that they sell for the is350 and that’s also soft. Reason why I went with the Kein mount.
#118
To confirm, would all the parts listed fit non IS F vehicle (IS 350 RWD), and should be replaced together;
12392-38020 (engine mount insulator)
12321-38020 (engine bracket)
12371-38110 (Insulator)
#119
Would like to confirm the following prior to placing order. Parts listed below will fit non IS F vehicle (06 -2013 IS 350 RWD), without issue. Part 12392-38020 shown in photo provided by Joe Z, is the insulator that is "sandwiched" between part 12371-38110 and part 12321-38020, andis part that becomes defective over time similar to a bushing however, part 12392-38020 (2015 - 2020 RC F), is stiffer than that installed in non IS F / RC F vehicle, correct?
Part number 12371-31070 (06 - 2015 IS 350 RWD), appears to be the complete mount and isolator as per photo however, unable to confirm.
Thank you in advance for any additional information prior to ordering parts per Joe z's photo.
