Transmission mount upgrade (KEIN)
#152
To confirm, I would remove the aluminum brace (four 14 mm nuts & four 12 mm nuts), then the the four 12 mm bolts attaching the trans mount to the transmission, without concerns of transmission coming down. The jack is only used to lift transmission to asset with installing the new trans mount. Is that correct?,
#153
Thanks for the follow up DMV8!
#154
Understood, thank you again JDMV8!
was concerned that nothing would be supporting the transmission and may drop down, once the aluminum brace and existing transmission mount were removed. Hopefully installation of the new mount wont need the assistance of a jack!!
#155
Part 12361-38230 Front Engine Mount L & R, (2008 Lexus IS F / RC F 2015 - 2021)
Part 12371-38110 Trans Mount (2008 Lexus IS F / RC F 2015 - 2019 )
#156
#157
Tech Info Resource
It holds the back of the transmission undertray.
#158
#159
Tech Info Resource
Yes, the photo is real.
#160
Want to again follow up and obtain clarification of removal / install process (DYI, before having the trans mount installed at a service center.
At what point is a jack needed to support / lift the transmission itself when installing new mount, and where is it recommended to place the jack along the transmission?
Reason for changing the mount in addition to routine maintenance, I've been experiencing a "surge" when coming to a stop. When approaching a stop sign and begin to slowly stop (from 30 mph), before coming to a complete stop, I feel a "surge forward", (feels from underneath front seat region) before the complete stop, and thought perhaps issue may be the transmission mount failing allowing the transmission to shift.
#161
Follow up to confirm when bracket that the trans mount is fasten is removed, is the transmission free and can possibly come down and jack is needed to support the transmission itself OR, the jack is only needed to push up on the transmission when installing the new trans mount to allow for additional room for installing the new trans mount?
Any additional information is appreciated.
#162
Tech Info Resource
It wouldn't be good to let the transmission hang on the car. Lots of unintended consequences and stress to parts not designed to support the engine and transmission on just two front mounts.
#163
#164
Tech Info Resource
Not correct. Support the transmission with a jack or jackstand like in the picture below where the jackstand is under the bell housing. Remove the bolts and the mount with the transmission still supported. Replace the mounts, torque all nuts and bolts to spec. Drop the jack after all bolts are fully tightened.
#165
