AoonuAuto LED door sills
Old Nov 9, 2019 | 10:31 AM
aring87's Avatar
aring87
Default AoonuAuto LED door sills
So I just received LED door sills from aoonuauto for my 2008 ISF and didn't realize that the door sill is connected to the panel and not separate. When I took it to my shop for the install they explained that they would have to cut the plastic, but it would not look clean as there would be a noticeable gap and wiring would be showing. Was just curious if anyone here have successfully installed door sill LED lights on their '08 ISF and if so which company did you use and did it look good?
Old Nov 9, 2019 | 04:44 PM
Vitveet's Avatar
Vitveet
Have a link to the ones you have?
V.
Old Nov 9, 2019 | 07:11 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
OEM Lexus from the IS350 Luxury model. Fun wiring them, but they fit perfectly and work exactly like factory because they ARE factory.
Old Nov 9, 2019 | 07:54 PM
2jzdc's Avatar
2jzdc
Do you have the part number for this?
Old Nov 10, 2019 | 12:37 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
There are two part numbers. For the IS F you need 67910-53030-C0 and 67920-53030-C0. There is also an ivory option, but that would look really ugly with everything else in black.
More info in these threads:
https://www.clublexus.com/forums/is-...ml#post2357802
https://www.clublexus.com/forums/is-...-w-photos.html
eddie420
Apr 7, 2020 11:03 AM
red93sc
RC - 1st Gen (2015-present)
43
Dec 8, 2016 10:16 PM
Gidovs
Nov 11, 2013 05:11 PM
RU514
Apr 26, 2012 07:10 PM
FoUr OuNcE
Jun 25, 2009 12:58 AM
