Help!! tires rubbing
My 2011 ISF is on kw coils with 20x9 fronts and 20x10.5 rears. I'm rubbing on any normal turn on the fronts and when I hit slopes in the road it rubs on the rears. Is this because I'm possibly sitting too low or are my tires too big? I believe the tires are 255 fronts and 285 or 295 rears.
I purchased the car as is and I believe the coils are at standard settings from the box. I can get the exact tire sizes when I get home from work. I called a shop and they said they can adjust the coils for $20 each side.
Raising the coilovers would be the easiest fix. The only way you can get away without rubbing that low is by having the proper offsets on your wheels (or lots of camber) and most aftermarket wheels are too aggressive for stock-like fitment. Many prefer this though and are going for a "hella flush" look instead of giving their vehicle a performance advantage with their modifications. Hopefully raising the rear a little and the front even more will solve your problems. I'm sure the fenders are already rolled, but if you're still rubbing you can see if they can be rolled further. Past that you would have to address the real issue...wheels with too aggressive an offset. You can always run a narrower tire, but what's the fun in that?
^^^^If that's true, your rear tires are 1" in OD larger than stock, IOW, too tall. The front tires are the correct OD. Even though the ISF uses staggered tires, the OD of the front and rear is the same at 26". Have you gone downstairs yet
And knowing the Offset is important.
Lou
Lou
Didn't the OE wheels and tires come with the sale? I would throw those on for the time being if you want the pleasure of driving your newly purchased F around, minus having to worry about dips in the road and/or damage to tires you may be looking to sell soon.
Lou
Lou
do i need 285 /25/20 on the rear?
^^^^295/25/20 would be closer to stock OD - 25.8", and will give you a "bit" more side wall. If your offset isn't to wild, that should work fine. Glad to see you made it downstairs
Lou
Lou
