Inconsistent lack of power problem with out a code error
2011 ISF 73k miles
Directly after an oil change my car would act as if it was taking off in 3rd gear, super bogged down. Then all of a sudden it would perform normally, for about 80 miles. The car will go back and forth, performing like this every 50-100 miles . I've taken it the the dealership a few times and with out it throwing a engine code, they can't do much. They plugged in their laptop and looked at all the readings, everything besides a low voltage reading from a knock sensor.
Has anyone experienced this?
How's it run in manual mode? Did you try resetting the ECU?
Edit: is the oil overfilled?
I had same issue right after oil change. I also noticed that the growl above 3500 RPM would sound different too. Turned out that the dealer left the very bottom portion of the airbox open when they checked my filter.
It is very difficult to see..you might have to feel the bottom of the box. I opened it up, removed the filter completetly and carefully made sure the bottom latched on correctly....no problem since.
The following 2 users liked this post by Vervish:
Inkedfiref (05-05-17),
JPxMODz (05-05-17)
Sponsor
Your dealer maybe overfilling the oil. When the ISF runs high oil level it literally belches oil out the crankcase PCV.
Rafi
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Kevinsprin
12-16-17 02:17 PM
Jerseyguy
RX - 1st Gen (1999-2003)
03-27-11 07:17 AM
