Replacing rear bumper reflectors...
just look at this thread and it is pretty similar... https://www.clublexus.com/forums/is-...ng-method.html
There are 2 bolts behind the wheels on the bottom of the bumper... 2 fasteners on the underside in the middle of the bumper you have to loosen away from the bottom plastic diffuser... there is one bolt behind the felt liner in the wheel well... just move the liner to the side after you remove the 2 bottom bolts as the bumper will be able to flail outwards to get in there a little better... i used an extension to get in there... again refer back to the above link to get a better understanding of this bolt behind the bumper... there will also be 2 bolts behind some covers near the lower rubber trunk liner...
If you have parking sensors, the wire is on the driver's side so don't let the bumper fall to the ground... it is held by a black plate with a screw... As i got the bumper fully detached, i would let it rest on the styrofoam reinforcement as that will give you enough space to unscrew that screw while it is sitting on the styrofoam... you can unscrew that and the bumper can rest on the ground afterwards...
For the wiring... you have to remove the bag hook... just a phillips screw... there's a fastener right above the hook where you can just wiggle from side to side with a flat head to remove the carpet liner... you will see the 3 wires going to the tailights... if you look downwards near the black plastic cover that the carpet meets, you will see the harness to where the wires go to the actual tailight and turn signal... the white with black stripe is the negative... the green wire is the parking light... the white with green stripe is the brake light... I routed it through the hole where the rubber boot is... just tap into the wires and voila...
I will post up pics later... i have a usb and got smoked lenses... but i got the "fiber optic" version rather most peeps i've seen on here got the regular SMD LED... these versions http://www.ebay.com/itm/FOR-TOYOTA-A...9WmCe4&vxp=mtr
the only thing with those is that the lens is actually fatter than stock so it sticks a lil further out than stock but it's not a noticeable protrusion... i just notice it as i hand wash and dry my car and i suck up the water with a towel that is usually left over in the crevice below these reflectors... it still sits inside the bumper so it's not hanging out...
LMK if you have any other questions...
here's the link where i purchased them from...
Amazon.com: iJDMTOY Lexus IS-F GX470 Toyota Sienna Matrix Venza Avalon Red Lens LED Bumper Reflector Lights: Automotive
thanks for the link man appreciate it
Double check that you've tapped into the right wires, I did this last week and found the best place to tap in is right before the light cluster.
Bumper is pretty simple. 2 bolts in the fender well attaching it to the quarter, 2 screws revealed when you open the trunk (pop the 2 tabs out), get the plastic clips under the bumper.
Once the bumper is off, just screw off the reflectors.
for the LED reflectors, tap 1 into the other and tap the 2 applicable wires into the tail light...very simple. The 3rd wire (which dims upon braking), tap into the brake light. I don't remember the color scheme, but it was fairly easy to do without any instructions (granted you're comfortable working with basic wire tapping).
If you have specific questions you can PM me...
