Swift spring users
Old Nov 2, 2014 | 07:51 PM
  #46
lobuxracer's Avatar
lobuxracer
Tech Resource
Every 2IS owner experiencing inside edge wear had toe well within Lexus spec. It doesn't mean it is good for wear issues.
https://www.clublexus.com/forums/is-...alignment.html
https://www.clublexus.com/forums/is-...eo-inside.html
Old Nov 2, 2014 | 10:42 PM
  #47
krue92's Avatar
krue92
Yeah I have read those threads. I actually had the alignment shop use the specs you posted in the alignment thread instead of the stock Lexus specs. I guess I'm just trying to figure out if I need to worry about my camber or if I will be fine. I don't want to spend more money on new control arms or ball joints if I don't need to. I guess time will tell... Ha
Thanks!
Old Jan 18, 2015 | 05:31 PM
  #48
SoCalISF's Avatar
SoCalISF
Default Swift lowered with a 235-265 tire combo...
After speaking with several CL members running Swift springs (either from and rear or front only), there was some discussion regarding the use of Michelin PSS in 235/40 for the front and 265/35 for the rear on an OEM wheel, either the early or late styles, either with or without spacers.
This in an effort to preserve ride quality, as opposed to the popular 245/35-275/30 combo, which in all probability negatively impacts ride quality, even if ever so slightly. The 235-265's are approximately .300 taller than the OEM 225-255's, with the 245-275's being approximately .300 shorter.
Anyone running the combo as described above?
Old Jan 19, 2015 | 01:09 PM
  #49
TonyDtiger's Avatar
TonyDtiger
So is anything required to fix the front camber or is it fine? Please help (tires aren't cheap) lol
Old Jan 19, 2015 | 09:11 PM
  #50
SoCalISF's Avatar
SoCalISF
Search the forums, info. is everywhere. Generally, it appears negative camber up to 2.0* is acceptable as long as the toe is addressed. Search for info. on factory alignment and rear LCA bushing flex under hard braking.
Old Jan 19, 2015 | 09:14 PM
  #51
SoCalISF's Avatar
SoCalISF
Start with the link in lobux' post ^^^^^ (#46).
Old Jan 21, 2015 | 10:49 AM
  #52
TonyDtiger's Avatar
TonyDtiger
I guess ill start with a realignment thanks guys
NAZTY97
RC - 1st Gen (2015-present)
Oct 31, 2018 03:55 PM
shyguyF
IS F (2008-2014)
Feb 12, 2016 07:05 PM
jpak000
Suspension
12
May 30, 2014 12:20 PM
daileycon
Suspension and Brakes
21
Feb 19, 2014 08:51 AM
LilMan23
Feb 5, 2010 06:21 PM
