Swift spring users
Old Oct 27, 2014 | 07:16 PM
  #31
krue92's Avatar
krue92
I think the front could use a 20mm spacer. The 15mm looks great on the back. Does 20mm work in the front or would that rub? I just see most people running 15mm all the way around and was curious if 20mm was an option.
Old Oct 29, 2014 | 01:51 PM
  #32
krue92's Avatar
krue92
I decided to get the alignment to see how it looks after that. Turns out the rear is fine and all within factory specs, but the camber in the front is too negative. Since our car has no camber adjustment, I will probably be buying some new SPC ball joints to resolve the issue.
Old Oct 29, 2014 | 07:57 PM
  #33
H60Driver's Avatar
H60Driver
Save your money! Camber is not the culprit to tire wear. Especially on our cars. I too was very skeptical. After reading up on why our car wears so bad on the inner front tire I decided to go with the Figs lower control arm bushing and align the front to as close to zero toe as possible. After driving like this for a year now I have zero abnormal wear on my tires lowered on swift springs and 15mm spacers.
Old Oct 29, 2014 | 11:55 PM
  #34
LexyISF's Avatar
LexyISF
Originally Posted by krue92
I installed my swift springs and 15mm spacers over the weekend and the car does look great now. I will snap some pics and post them up today after I clean the car. Back looks about perfect and the front looks good too, but I probably could of done a 20mm spacer in the front. Not sure if it would rub though. I trimmed the bump stops about 1/2 inch in the front and back. No issues when driving and no rubbing at all. The springs do ride about the same as stock to me. I just figured it was safer to do 15mm all the way around to keep it the same. Definitely happy with the outcome though.
yes post some pics please!
My friend here in Australia has swift springs and 20mm spacers all round, and he said the front wheels rub the fender liners. The fix is either cut out fender liner where it rubs, or use a heat gun and mould it.
I went for 15mm spacers because that seems to be the normal on here. Can't wait to get mine installed! The H&R DRS kit with extended studs looks very quality! I'm happy I got these instead of the Ichiba V1 ones.
What was the camber reading? I was told by a few guys that race that you won't really see tire wear from camber below about -2.5 deg. My last alignment I went to zero toe in the front and pretty much eliminated my front tire wear problems that I had with the OEM set up.
Old Oct 30, 2014 | 12:00 AM
  #35
LexyISF's Avatar
LexyISF
Awesome! I'm running zero toe (before spring install) and inner wear looks to be eliminated. I've done about 10,000kms on my 245/275 Michelin PSS tires and they still look great. These should last much longer than the 30,000kms I got out of the OEM Bridgestones.
How do you find the LCA bushing? Can you notice anything? I can buy that locally as it's a SuperPro product, seems like a good upgrade for sure.
Old Oct 30, 2014 | 04:14 AM
  #36
H60Driver's Avatar
H60Driver
I bought mine here. There's a pretty good video showing how crappy the OEM bushings are. I didn't notice any difference as far as the ride goes.
http://shopfigs.com/v1/index.php?rou...product_id=138
Old Oct 30, 2014 | 07:31 AM
  #37
krue92's Avatar
krue92
My car was -2.1 on one side and -1.8 on the other side. I will get some pics posted today. I just can look at the front tire and tell its cambered and that's what bothers me the most. The car does look great with the 15mm spacers, but I just thought the front could come out a little more. I think if I got the camber fixed it would probably look better because the wheel wouldn't be tilted in as much.
Old Oct 30, 2014 | 02:51 PM
  #38
lobuxracer's Avatar
lobuxracer
Tech Resource
It won't fix the wear problem though. Toe out is the culprit.
Old Oct 30, 2014 | 03:15 PM
  #39
Vervish's Avatar
Vervish
Is the figs lower control arm a requirement to zero out the toe issue or can it be dialed in on stock suspension with lowering springs?
Old Oct 30, 2014 | 03:19 PM
  #40
krue92's Avatar
krue92
I think the Toe is fine on mine. The only thing that was not within spec was the camber. So are you saying with negative camber like I have the tires will wear fine.?
Old Oct 30, 2014 | 04:32 PM
  #41
krue92's Avatar
krue92
Pics after springs and 15mm spacers...I love how the sun shines on the Pearl, so I had to post these first.
Attached Thumbnails Swift spring users-20141030_175249-large-.jpg   Swift spring users-20141030_175301-large-.jpg   Swift spring users-20141030_175312-large-.jpg   Swift spring users-20141030_175319-large-.jpg   Swift spring users-20141030_175348-large-.jpg
Old Oct 30, 2014 | 04:34 PM
  #42
krue92's Avatar
krue92
Few more pics...
Attached Thumbnails Swift spring users-20141030_175354-large-.jpg   Swift spring users-20141030_175405-large-.jpg   Swift spring users-20141030_175411-large-.jpg   Swift spring users-20141030_175429-large-.jpg
Old Oct 30, 2014 | 04:54 PM
  #43
Vervish's Avatar
Vervish
Awesome! Very nice..
Can't wait to do my spacers..
Old Oct 31, 2014 | 09:13 AM
  #44
lobuxracer's Avatar
lobuxracer
Tech Resource
What makes you believe toe is fine? It is the primary reason for inside (or outside) edge wear in any wheel with less than 2.5 degrees of camber. If you have more than 2.5 degrees of camber, then you would need camber correction. I run -2.0 on all four corners of my Supra and have no issues with tire wear as long as the toe is set right.
Old Oct 31, 2014 | 03:48 PM
  #45
krue92's Avatar
krue92
I just had it aligned a couple days ago and the sheet they gave me afterwards showed the toe in spec for the front. The only thing that was out of spec was the Camber and Caster. Left side was -1.8 for camber and 6.7 for caster and -2.1 for camber and 7.1 for caster on the right side.
