Question on Paddle Shifters
Hey Guys,
Hoping someone might be able to answer my question on the paddle shifters.
Basically, can I still use my IS-F if I remove them? Only reason I ask is I want to send them off to my carbon guy for skinning in real carbon fibre.
Let me know.
Thanks.
Peter
Let me know.
Thanks.
Peter
I believe the paddles have the sensor integrated into them but they diconnect. I am sure you can drive without them, but you may get a CEL.
Here is my walkthrough with photos in case you need it.
https://www.clublexus.com/forums/is-...k-through.html
You were a huge help for when I removed my OEM steering wheel, and fitted a flat bottom version a few weeks back.
I actually used a few of your photos to do a DIY thread over on the UK forum. Gave you a shout out as a thanks for the help!
As long as it won't stop me/the wife using the car, I'll whip them off and send them to my carbon guy for skinning!
Just the normal carbon fibre colour.
I've already started on my interior. The rear centre armrest was re-skinned in real carbon fibre a few weeks ago. You can see a picture of it on my thread (ISF from over the pond - or something like that! Lol).
Just waiting to get back my door switch covers back (re-done in real carbon as opposed to the silver OEM stuff!).
Then it's centre console, ashtray lid, cubby lid, and the paddle shifters.
It won't set a CEL. There's no wire check for the paddles or the up/down feature on the stick as there are only two wires. It's impossible to run a wire check on a normally open circuit.
Guessing I should be ok to use the car without them then?
I can't see why it should be an issue.
How is real carbon with clear coat cheap?! Hardly any carbon parts are 100% carbon fibre unless you spend mega bucks?! Most are coated on fibreglass or plastic.
As I said, it's a personal choice, and something I like that's a bit different.
Mooney6959
Apr 7, 2008 09:24 PM
