Weird noises
Old Dec 19, 2012 | 09:07 AM
tgui's Avatar
tgui
How odd. No one else is reporting this issue despite track days and high mileage. To what do you attribute this? Magic sparkplugs?
How very constructive. Lets all try harder to foster a sense of community and huggy goodness.
My car currently suffers from rough idle at the same ~500 RPMs. I see this issue through stable and varied temperatures, so ECU learning as the seasons change probably isn't the issue.
Fouled plugs could be the culprit and might be a solution. It has in the past worked for my other performance cars, and possibly further supported by the above annecdotal evidence.
Old Dec 19, 2012 | 05:17 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Maybe some homework is in order. The OEM plugs are already iridium with three electrodes, and they're not known for having issues, so changing to a different plug is no guarantee the problem is solved. It could just as easily be a marginal coil, bad battery, or a host of other things. Telling someone to install a plug not designed for this particular combustion chamber and assuming it will work is guessing at best.
There are a number of unique things about these engines. Assuming past knowledge of performance engines is applicable to this platform is making a mistake.
I track my car. It has seen much harder use than most. I don't have these issues, and they've not been a common issue reported except in this thread. While my answer may have appeared glib, fouled plugs on this engine would be exceptionally odd. I too have a very long history of working on high performance engines for street and track.
lincolnlee
Sep 26, 2018 04:48 AM
cwwplex12
Sep 15, 2016 06:14 PM
DonnaNX
NX - 1st Gen (2015-2021)
Jan 10, 2016 05:49 AM
grindin8o8
Oct 4, 2009 08:20 AM
SNFL
GS - 1st Gen (1993-1997)
Sep 8, 2008 11:23 AM
