NX - 1st Gen (2015-2021)
Anyone with PCS having an issue?
Old Jan 8, 2016 | 08:01 AM
DonnaNX's Avatar
DonnaNX
Default Anyone with PCS having an issue?
I am still having a problem with the PCS going off randomly. It does it about 3x day now, and I don't put that many miles on the car each day. So, I'm estimating that within a 20-mile span the PCS goes off about 3 times. I've had dealer service check it out and they can't find any issues with the car. This happens even when there is no other traffic around. I'm at a loss and am getting frustrated. It's kind of startling when the "brake" light flashes along with the warning beeps.
I know I can turn the PCS off, but it just reactivates each time I start the car. Anyone else having a problem?
Old Jan 8, 2016 | 08:41 AM
Swacer's Avatar
Swacer
Mine has gone off once randomly going down a backroad with sharp turns. I reduced the distance and haven't had a problem since. However, I find PCS annoying in general, as there are a number of time I have been coming to stop and the brake system decided to BRAKE for me.
it usually ends with me in a tirade
Old Jan 8, 2016 | 10:50 AM
LexBob2's Avatar
LexBob2
I hope your tirade doesn't turn into road range.
Old Jan 8, 2016 | 10:58 AM
Swacer's Avatar
Swacer
Surprisingly I never have road rage. lol
Old Jan 8, 2016 | 01:02 PM
miop4000's Avatar
miop4000
The system in the NX does seem more sensitive than others I have driven. There are a number of situations when it triggers inadvertently. From the manual:
■ Conditions that may trigger the system even if there is no possibility of a collision
If the following obstructs the front of the sensor, the system judges that a collision may be possible and operates.
● When passing by a vehicle while making left or right turns or passing a vehicle in an opposite lane.
● When the vehicle rapidly approaches an object in front of it (such as another vehicle, toll gate, etc.)
● When climbing a steep hill, etc., and there are structures in the upper region of the road (billboards, low ceilings, street lamps, etc.)
● When driving through narrow passages or places with low ceilings (bridges, tunnels, overhead passes, etc.)
● When driving on an uneven road surface
● When metal objects are on the road surface causing level differences or protrusions in the road
● When an extreme change in vehicle height occurs
● When the radar sensor moves off position due to its surrounding area being subjected to a strong impact.
● When there is an obstacle on the side of an entrance of a curb for road (guardrails, etc.)
● When your vehicle is tilted upwards (due to towing a trailer or during emergency tow-
ing, heavy loads in the luggage compartment, etc.).
When the system is activated in the situations described above, there is also a possibility that the brakes will be applied with a force greater than normal.
I find the first situation the most common.
The other option is that you can reduce sensitivity rather than switch the system off entirely. From the manual:
Changing the pre-collision system
Changing the alert timing of the pre-collision system
Each time the PCS switch is pressed, the response to the distance changes as follows.
1 Far
2 Middle*
3 Near
*: Default setting
Turning off the pre-collision system Press the PCS switch for 3 seconds
The PCS warning light turns on and a message is shown on the multi-infor- mation display.
To turn on the system, press the PCS switch again. The system is set to ON each time the engine switch is turned to IGNITION ON mode.
Old Jan 10, 2016 | 05:49 AM
Mr645's Avatar
Mr645
I would perhaps suggest turning it off. It seems easy enough to pay attention and activate the brake with my right foot when required.
DonnaNX
15
Nov 17, 2015 07:38 PM
sliderman
RX - 1st Gen (1999-2003)
May 6, 2015 08:17 AM
silo113
Apr 19, 2010 04:59 PM
audvid
May 9, 2008 10:19 AM
