ISF with IS350 Diff...
Old Sep 9, 2012 | 04:43 PM
  #91
MRxSLAYx's Avatar
MRxSLAYx
Originally Posted by darbs242
Ok so i got my is350 diff installed today and the acceleration increase from 0-120 is very noticeable but the car is done...(not out of gear) but just falls on its face about half way threw 7th gear at 130-135. It feels like the computer pulls timing or something. The power is just gone.
First gear is a complete smoke show, the car picks up traction yet is still spinning threw second, third locks up and your gone. Then your at that 130mph wall before you can get over acceleration. If you don't care about top end, gas isn't your top priority and you haven't done this mod im not sure whats wrong with you. It brings the term HOT ROD to the ISF.
My buddy took some video il put up later with and without a 100 shot No2 on with the is350 diff installed 5-100mph in 9-10sec on street tires
Thanks for the update. Do you have an AFR gauge? If so, was the car running real rich in 7th?
Old Sep 9, 2012 | 05:16 PM
  #92
darbs242's Avatar
darbs242
No but i could hook up a solus ultra to the car and have someone watch it while i drive
Old Sep 9, 2012 | 05:19 PM
  #93
crazymikie's Avatar
crazymikie
Interesting- I wonder if there is something coded for fuel efficiency in 7th and 8th gears. If you do the math out, there shouldn't be that much of a difference between the overall ratio in 5th gear with the OEM diff (3.61:1) vs 7th with the IS350 diff (3.37:1) .
I have an IS350 diff on the way and I'll report back once I get it installed as well.
Old Sep 9, 2012 | 06:02 PM
  #94
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by crazymikie
Given that it uses the same pinion bearing, I should be able to swap the gears from a 2SC into either an IS350 case or an ISF case, though?
http://www.lexussouthatlantaparts.co...tial%20carrier
This would be really cool, but unfortunately, the early SC uses the same geometry as the Supra, and the later SC uses a 3.769 gear with the same bearing as the IS F. You'd need to buy parts and test for this one. I agree, a 3.266 would be a nice street gear.
Old Sep 9, 2012 | 06:07 PM
  #95
obby's Avatar
obby
nice!!! i did notice that too when i hit 7th or 8th gear the car feel like it doesnt pull anymore.
Old Sep 9, 2012 | 07:20 PM
  #96
darbs242's Avatar
darbs242
Here are some videos from the testing of the IS350 rear differential in my ISF
4.09 wIth 100 shot, coming on in 3rd gear via nitrous controller
http://youtu.be/iIB2nkLmUzQ
N/A pulls with 4.09
http://youtu.be/FF2eCJsbqwU
This is 6ish minute but goes threw me realizing the car will cut out at about 130mph with the 4.09 in 7th gear. you can hear the car die down from the computer and its just done.... Its really weird and quite obnoxious.
http://youtu.be/FX9xKthC8TU
Old Sep 9, 2012 | 08:33 PM
  #97
darbs242's Avatar
darbs242
If 7th gear does have a fuel efficiency hard code the GS 430 3.7 rear end is the way to go. First would be a little more livable, car would still do 150mph and 8th would be a little better for for highway cruising. I like auto more with the up'ed final drive. When you give the car gas it doesn't have to down shift as much to get not the power. Car should have like a 3.5 rear gear from the factory, would be perfect.
Old Sep 10, 2012 | 07:17 AM
  #98
crazymikie's Avatar
crazymikie
I take my original guess back- I think you are hitting the hard speed limiter:
https://www.clublexus.com/forums/is-...top-speed.html
180 mph would be around 5500 RPM in 7th gear, which is right where 130 mph is with the 4.09. I guess they must have coded the ECU to cut at a certain RPM/gear combo as opposed to speed.
It looks like HKS makes a speed limiter removal tool for the Japanese market, but it's like $1,500.
Old Sep 10, 2012 | 10:16 AM
  #99
crazymikie's Avatar
crazymikie
I found an earlier SC diff for a decent price. When I put the IS350 diff in my car, I can pull the stocker and the SC apart and see how it looks.
Old Sep 10, 2012 | 12:09 PM
  #100
Jowett's Avatar
Jowett
Looks like the SC 3.26 diff is the earlier 8" size. The 8.2, which is the 06 and up SC, will have 3.76.
Old Sep 10, 2012 | 04:55 PM
  #101
TrackLight's Avatar
TrackLight
If it is the speed limiter, I think that Sard and Toms make something as well. From memory though, both of those and the HKS unit ran ~ $2,000.
Old Sep 10, 2012 | 05:12 PM
  #102
Meanstreak's Avatar
Meanstreak
As i was reading through this and watching the videos and was thinking the same thing! Thanks for the spreadsheet confirming the 7th gear rpms. I was just getting ready to put one together
Darbs - thanks for the vids. Can't wait to see how it impacts your 1/4 mile times. When will you run again?
Old Sep 10, 2012 | 06:51 PM
  #103
darbs242's Avatar
darbs242
Il be at the track on Saturday with MS109, 150 shot, the new nitrous controller & obviously the diff. I think im going to shift around 6,5oo rpm because with the 4.09 the transmission only drops 900-1500 rpm when you shift and that will keep me in the peak of the power. Should make between 550-575 hp and 575-600tq at the wheels once the juice kicks in. I have it set to spray in 3rd and up at WOT between 3000-6400 rpm... il probably run my slicks around 11 psi. Wish me luck
Old Sep 10, 2012 | 09:05 PM
  #104
obby's Avatar
obby
cant wait to see the result with the new diff..GL
Old Sep 11, 2012 | 05:08 AM
  #105
MRxSLAYx's Avatar
MRxSLAYx
Good luck on saturday! Is your shot calculated for hp to the wheels? 575whp is going to be somewhere in the 200 shot range.
