ISF with IS350 Diff...
Old Sep 11, 2012 | 05:16 AM
  #106
Meanstreak's Avatar
Meanstreak
Originally Posted by darbs242
Il be at the track on Saturday with MS109, 150 shot, the new nitrous controller & obviously the diff. I think im going to shift around 6,5oo rpm because with the 4.09 the transmission only drops 900-1500 rpm when you shift and that will keep me in the peak of the power. Should make between 550-575 hp and 575-600tq at the wheels once the juice kicks in. I have it set to spray in 3rd and up at WOT between 3000-6400 rpm... il probably run my slicks around 11 psi. Wish me luck
Go get 'em!
Old Sep 11, 2012 | 10:31 AM
  #107
Dv8tion388's Avatar
Dv8tion388
Good luck to you Ryan! There shouldnt be any reason to leave there without a 10 sec timeslip in hand.
~Dv8
Old Sep 11, 2012 | 07:45 PM
  #108
darbs242's Avatar
darbs242
Originally Posted by MRxSLAYx
Good luck on saturday! Is your shot calculated for hp to the wheels? 575whp is going to be somewhere in the 200 shot range.
Maybe I over shot a bit... Call it 550 then
Old Sep 15, 2012 | 09:06 AM
  #109
crazymikie's Avatar
crazymikie
Ok- I give up. How do you get the axles out of the diff. Got all the bolts out and tried lowering it a bit and prying the axles out, but no luck.
Any suggestions?
Thanks!
Old Sep 15, 2012 | 09:23 AM
  #110
obby's Avatar
obby
i broke my axle loose prior to lowering the diff. I use a big flat head and stuck it in between the axle and the diff and pry it out until i feel the lock ring pop. from there i lower it half way down then pull it out..
Old Sep 15, 2012 | 09:31 AM
  #111
crazymikie's Avatar
crazymikie
I'll give it a whirl again. I tried with a pry bar, but I'll give it another shot.
Thanks!
Mike
Old Sep 15, 2012 | 11:28 AM
  #112
crazymikie's Avatar
crazymikie
Axles are out, driveshaft is disconnected and I dropped the axleback out of the way, but there doesn't seem to be any way to get the diff out.
What else am I supposed to disconnect? Everything is moving, but there isn't clearance enough to get the axle out of the diff, no matter which way I move it.
Old Sep 15, 2012 | 11:52 AM
  #113
obby's Avatar
obby
im guessing you are doing this with jack stand, if so you will have to jack it up pretty high and from there pull 1 axle out at a time.
Old Sep 15, 2012 | 11:54 AM
  #114
obby's Avatar
obby
also use a rubber mallet and hit the axle out..
Old Sep 15, 2012 | 12:01 PM
  #115
crazymikie's Avatar
crazymikie
It's up pretty high. The axle is hitting the lower control arm so i don't think height is an issue.
Did you disconnect the control arms?
Old Sep 15, 2012 | 12:13 PM
  #116
obby's Avatar
obby
nope.. just both of those cross bars in each side.
Old Sep 15, 2012 | 03:18 PM
  #117
crazymikie's Avatar
crazymikie
DOH!
I guess I should have looked closer at that. That did the trick. For anyone else who isn't the sharpest at turning wrenches (like me) if you pull off the two plastic triangle pieces (they are held on with two small nuts on each side), you'll see the cross braces.
One axle is out. the other snapped back in when I was fighting with it. I'll have to bolt the thing back up tomorrow, pop the other axle out and finish the swap.
I did my F-Sport sway while I was under there. Of course, that had to fight me as well. I ended up having to pull the end links out completely and clean up the threads before I could get the nuts off. Hopefully, everything will be done tomorrow.
Thanks, again, Obby.
Old Sep 15, 2012 | 05:37 PM
  #118
darbs242's Avatar
darbs242
Just got back from the track... Only got one run in before it started raining.... 11.6 at 127mph god dam I hate rain... I will be back soon to try again with those trap speeds 10s should not come hard
Old Sep 15, 2012 | 07:33 PM
  #119
MRxSLAYx's Avatar
MRxSLAYx
Nice run. 127mph is decent for your power range. How was your 60'?
Old Sep 16, 2012 | 05:27 AM
  #120
darbs242's Avatar
darbs242
It had ben raining all day on and off so the rubber on the track sucked.. I ran a 2.01 60ft. I was hitting the speed limiter just before I crossed the line. I think the 4.09 diff is a toss up on high power ifs because it rips threw gears so fast is barely has time to put some power down and I think I hurt my 60 ft cause I was spinning more with the new gearing. I will prob put my stock diff back in the car or try a 3.7 from a gs
