Brake fluid recomendations
Old May 10, 2022 | 06:58 AM
  #46
dannyk1113's Avatar
dannyk1113
Originally Posted by ultimase
I ran OEM brake fluid on a short track day, and then changed it to motul on another track day. As much as I think you'll hate hearing this...there was a significant difference with the motul fluid, and that was on a short lap day, typically 3-4 laps followed by 30-45 mins cool down. If you're lapping for an extended amount of time, the motul will likely mean the difference between boiling the fluid versus not.
interesting, which track?
Old May 10, 2022 | 12:08 PM
  #47
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by dannyk1113
thanks for the reply, by current setup do u mean current fluid with track pads, or current fluid with my street pads. Last thing I wanna do is destroy my pads and then have nothing to drive home with!
Only the fluid. Pads depend on the track. Some tracks are OK for dual purpose pads, some are race pad only.
AFA the Motul making a difference - not really unless you're cooking the brakes. What makes you think this is bleeding the brakes and getting the bubbles out. Brakes ALWAYS feel better after a bleed regardless of fluid brand. This is also the reason so many buy braided stainless steel wrapped brake lines and say their pedal feels so much better. It's not the lines. It's bleeding the bubbles out because nobody bleeds their brakes, tests them, then installs braided stainless lines and tests again.
Old May 10, 2022 | 12:26 PM
  #48
lexicon72's Avatar
lexicon72
Hey there, I think I shared this list with you in our FB chat (this is Rick BTW).
https://www.lelandwest.com/brake-flu...ison-chart.cfm
I ran OEM fluid and high temp street pads (Stoptech Sport) for a few years without issue. You will be fine for now. But next fluid change, you might as well upgrade to hi temp fluid.
After I had a few years experience, I made the mistake of upgrading to track pads but still OEM fluid and boiled the fluid and lost all braking on track. Very scary moment that could have been catastrophic. Lesson learned.
I've run Project Mu G-Four and now Castol SRF.
See you on the 13th! 😉
Old May 10, 2022 | 01:48 PM
  #49
lobuxracer's Avatar
lobuxracer
Tech Resource
After i have a few years experience, I made the mistake of upgrading to track pads but still OEM fluid and boiled the fluid and lost all braking on track. Very scary moment that could have been catastrophic. Lesson learned.
Looks like the current "best" from a price/performance perspective is AFCO. The price listed on the site is a little low, but even at $24.95 list price, it's cheap and has a very high wet boiling point. Dry boiling point is academic. Sort by wet boiling point and look at price per ounce for your best bargain. And you can't beat Castrol SRF for performance. Nothing else is close.
Old Aug 29, 2022 | 03:58 PM
  #50
Rossi's Avatar
Rossi
Is ATE TYP200 good choice?
I currently run Project Mu G-four 335 in my ISF, the car will never see the track.
I have a brand new can of the ATE TYP200 (1L) left over from my other brake job. Thoughts please?
Old Aug 29, 2022 | 07:02 PM
  #51
lobuxracer's Avatar
lobuxracer
Tech Resource
ATE is good fluid. I'd run it especially if I wasn't tracking.
RaulTX
RC F (2015-present)
Jul 15, 2017 07:09 PM
amiehe
Suspension and Brakes
Apr 21, 2011 05:49 PM
Lexusfreak
17
Jan 16, 2008 02:47 AM
TexasGS
Apr 27, 2006 08:23 AM
ifilrx
Oct 31, 2005 08:01 AM
