Front UCA Proto pics.
Adjustable caster and camber, plus and minus. Still working on fitting them up, these are just tacked to maintain geometry in case I need to make adjustments.
Upper sperical is a Aurora Teflon lined precision AM series. Chromo tapered stud, .125 wall sheetmetal.The final design will be fully machine bent, this was laser cut at the bend lines to make it easy to assemble and verify.
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Yes in this round. I am considering a ID/OD coupler on the inner mount and a few other options, just need to get one rev out and then enhance it.
__________________
Great work FIGS,
i have seen a couple of your modifications around and just want to say thanks for taking the inital step in the modification process since there is no a lot for the ISF.
Is there a place where we could go and see your parts aplications list. I did notice you have a facebook, however I do not participate in facebook.
Great work FIGS,
__________________
Meraki Autoworks
CL Vendor Products for 3IS
Aug 19, 2017 06:10 PM
