o2 sensor
Old Jun 27, 2011 | 04:37 PM
lukeisf's Avatar
lukeisf
Default o2 sensor
Has anyone found a cheap place to buy o2 sensors. The reason I ask is I'm getting the ppe headers installed and they can strip easily and the dealer wants 323.00 for one so two would cost more then the install.
Old Jun 27, 2011 | 05:26 PM
OneSiCkF's Avatar
OneSiCkF
As long as they use the proper tool you should be ok.
Old Jun 27, 2011 | 07:26 PM
Nate008's Avatar
Nate008
Can someone chime in thats knowledgeable and post the proper tool for our cars?
I found the 1 below...I have heard of a special socket to remove o2 sensors and would like to install my Joe Z exhaust on base rather than pay someone to do it.
http://www.autozone.com/autozone/acc...er=272729_0_0_
Old Jun 27, 2011 | 09:20 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Look at this thread:
https://www.clublexus.com/forums/is-...-f-w-pics.html
Scroll down to post #6
Lou
Old Jun 27, 2011 | 09:58 PM
Nate008's Avatar
Nate008
Damn you Lou lol. I have seen that thread before too and even have it bookmarked at work. SMH. Thank you for reminding me how forgetful I am
Old Jun 28, 2011 | 07:56 PM
tenspeed's Avatar
tenspeed
RockAuto has them from $70 to $330. Eight choices.
http://www.rockauto.com/catalog/raframecatalog.php
Old Jun 29, 2011 | 04:44 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Sort of. There are two locations - upstream and downstream. For the exhaust system, you want the downstream O2 sensor. For a header install, you'd want the upstream sensor. Considering they have the OEM Denso units, I'd buy them first because they're most likely to be plug n' play where other units may require wire splicing to work. Definitely not what you'd prefer in a device producing microamps of current to do what it does.
Old Jun 29, 2011 | 05:02 AM
J2K's Avatar
J2K
CL Folding 100,000
Here's an OEM O2 sensor on ebay for $99.99 ---> http://shop.ebay.com/i.html?_kw=lexu...ensor&_kw=IS-F
Old Jun 29, 2011 | 05:45 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
And it's even the correct one for an exhaust install! Amazing.
RedlineAZ
IS F (2008-2014)
Jul 15, 2014 09:09 AM
eoph
IS F (2008-2014)
Jul 11, 2012 07:21 AM
Sup2jzgte
Apr 1, 2009 05:04 PM
combfilter
Oct 3, 2007 02:09 PM
