Just about 22k and I replaced all 4 rotors and pads. The only bits that still have life left in them was the rear pads. I replaced everything because I didn't want new rotors to have old pads.
When I bought the car it had 2 stickers on the window. One stated the tires don't last beyond 20k and the brakes 20K.
My car has 16000 kms which is roughly 10K miles and I had to change the front pads. the discs are OK but will need to go next time, the rear pads and rotors are still OK
I replaced my tires at 14K miles. While the wheels were off I inspected the brake pads and the rotors. They looked fine to me. IMHO, the pads still had a lot of meat left.
16k
had to replace front pads and rotors
its been to willowsprings once
you might be able to get away with resurfacing them once but run the risk of stress cracks
3 weekends at CMP. A little over 35k miles on the brakes. Front and rear pads were replaced with Carbotech 1521 Bobcats for street. OEM pads still have LOTS of meat on them, but I didn't like the dust. Track pads are XP12 front and XP10 rear. Rear rotors are doing well, front rotors have cracks approaching 3/4", but no cracks to root, edge, or between two holes.
Bought a used set of OEM front rotors on eBay with about 25% service life left, and I'll be installing them (probably) this week. They were $50 for the pair - hard to pass up at that price.
Resurfacing is usually a bad idea. It only reduces service life and if done incorrectly can lead to stopping power issues and accelerated pad wear. Watch this video - Scratching the Surface. These guys actually know what they're talking about.
Very nice video. I agree don't resurface. Measure the thickness of the rotors and once they are under min spec, replace them. I had some brake pad material removed from my rotors with an abrasive pad at the dealer. Brakes felt teribble with transeferred pad material and not much better after. Replaced rotors but still on older pads. Putting in new pads will hopefully solve the issue.
