Official IS-F Modification Thread
Old Jan 25, 2017 | 04:30 PM
  #466
FFM's Avatar
FFM
Anyone tried the CF version? Looks like it's from the same vendor as the ABS one. I haven't found one offered in obsidian and by the time you pay to paint it you're likely around the cost of the CF.
06-13 Lexus IS250 IS350 ISF Carbon Fiber CF IK Style Rear Trunk Spoiler Wing https://www.amazon.com/dp/B00PICLTBY..._1kuIyb2ADT70P
Old Jan 25, 2017 | 05:05 PM
  #467
St4nc3's Avatar
St4nc3
yeah i have the CF trunk spoiler pretty good fitment IMO
Old Jan 25, 2017 | 05:19 PM
  #468
FFM's Avatar
FFM
Oh sweet. Looks like I'll go that option. I like the idea of ABS more but don't feel like painting it.
Old Jan 25, 2017 | 06:42 PM
  #469
ROYALISF's Avatar
ROYALISF
I'm confused on what color is close to MM. they have Glacier Frost #074 but I thought that was closer to white?
Old Jan 26, 2017 | 09:05 AM
  #470
St4nc3's Avatar
St4nc3
its close enough but you can see a bit of a difference
08-14 ISF paint code.
06-13 IS250/350 Paint code.
Old Jan 26, 2017 | 09:50 AM
  #471
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^. Couple of things:
1. There is a difference between a mica paint and a metallic paint. Metalic has metal flake.
2. Mercury Metallic (1F2) did not come on the 2014 ISF. It was replaced by Liquid Platinum (1J2)
3. The closest color to MM (1F2) is Tungsten Pearl (1G1). My wife had an '08 ES350, when they were parked side by side in the garage they looked like the same color, except when they were in sunlight and you could see the metal flake in mine.
Lou
Old Jan 26, 2017 | 10:56 AM
  #472
St4nc3's Avatar
St4nc3
Lou
Thanks Lou. sorry i didnt get too into the details but yes you're right
Old Jan 27, 2017 | 07:24 AM
  #473
alex2192's Avatar
alex2192
Hey Everyone,
Looking to gut or completely cut out my primary cats.
Can anyone shed some light on how long it takes to get this done?
Also will i be getting check engines?
Thanks
Old Jan 27, 2017 | 09:31 AM
  #474
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^You can do it with a large drill. Takes awhile, but really not too hard.
Yes, you will get a cel unless you install an o2 Conditioner that you can get from PPE.
Lou
Old Jan 27, 2017 | 10:41 AM
  #475
Joker4096's Avatar
Joker4096
Originally Posted by alex2192
Hey Everyone,
Thanks
There is already a thread on this. I've done it. My suggestion, get the car on a lift. You will get a check engine for catalyst inefficient. You need O2 conditioners. I am running the RR racing one and it has worked wonderfully.
Old Feb 13, 2017 | 06:54 PM
  #476
supersonic's Avatar
supersonic
a couple of things. i really got spoiled by the tight handling of my 370Z and have notcied how "floaty" the F can be over corners and even triple digits. im not a big suspension guy and never done any suspension mods before but im looking at the USRS from RRracing. will that help quite a bit of the handling situation? i really dont want to change the suspension dynamic too much except get everything "tighter." i was also thinking the F-Sport rear sway bar as well. inputs from anyone? im not interested in lowering my car as it is a DD.
Old Feb 13, 2017 | 08:17 PM
  #477
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Oh, YES Indeed:
See this thread:
https://www.clublexus.com/forums/is-...rr-racing.html
My Post is on Pg. 11:
https://www.clublexus.com/forums/is-...racing-11.html
As well as improved handling, you'll get improved brake response due to much lessoned dive. I recommend them highly.
I also have the F-Sport rear bar, I recommend that also
Lou
Old Feb 13, 2017 | 11:18 PM
  #478
supersonic's Avatar
supersonic
^^^^Oh, YES Indeed:
See this thread:
Lou
thank you so much. ive been looking into this for a while and you've sold me. now is the FIGS more "looser" than the USRS from RR? someone noted its a 90 bushing compared to the 95 RR uses. also a lot of ppl put the rear sway bar on but i havent heard too much for the FRONT sway bar...that necessary?
Old Feb 14, 2017 | 05:43 AM
  #479
STLblueF's Avatar
STLblueF
Front sway bar is the same diameter as the f-sport front sway bar, from what I understand.
Old Feb 14, 2017 | 06:23 AM
  #480
Rickna's Avatar
Rickna
Yes, it is.
