IS C Discussion about the convertible IS C model
Add window switch to 2010 IS350c
Old 08-14-19, 08:07 PM
jj68jam
jj68jam's Avatar
Default Add window switch to 2010 IS350c
Hello! I’m getting close to buying a 2010 IS350c and noticed it does not have the window switch next to the top down button like the 2011-2015 models. Is the electrical connector the same to where it can be added? I am hoping it is since the top down button lowers the windows as part of the function.
I have found tons of info on your forum on these cars which has really helped me during my search. I really appreciate the fact that this forum was put together!
Thanks- Jim
Fort Lauderdale, Fl
Old 08-15-19, 11:04 AM
jj68jam
jj68jam's Avatar
Here is a pic of what the 2010 has instead of the double switch for reference- Thanks everyone! -Jim
Old 08-15-19, 11:26 PM
DennisMik
DennisMik's Avatar
Since the button to lower/raise all the windows was not a feature of the car until the 2011 model, I seriously doubt that the 2010 (and older) will have the wiring for it.
twleblanc (08-19-19)
Old 08-17-19, 06:09 PM
jj68jam
jj68jam's Avatar
Thanks for your input Dennis
Old 08-17-19, 10:47 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The 2010 switch has a 6-pin connector, while the 2011+ has an 8-pin connector.
On the computer end of things, I think you'd be in a bit more luck though, as the 2010 roof control computer changes up to the 2011+ computer, which means you'd be able to get a 2011+ computer and swap it in, then add the appropriate wiring.
Jeff
redspencer (08-20-19)
Old 08-18-19, 07:45 AM
jj68jam
jj68jam's Avatar
Great info- thanks for sharing Jeff! Still searching for my first IS350c- there is a local 2010 in the blue I like but I wonder if I should keep searching for a newer model- the switch, LED strip lights...etc. Thanks again!
-Jim
Old 08-19-19, 01:07 PM
fknISC808
fknISC808's Avatar
This is how my 2010 looks like when I got it. Doesn't look like this anymore though lol. Have a digital air pressure gauge there now. Good luck on your search for your 350C
terror83
05-23-19 02:08 PM
Gassho
RX - 3rd Gen (2010-2015)
07-28-18 12:59 PM
mb001
RX - 1st Gen (1999-2003)
10-10-14 08:37 AM
Quick Reply: Add window switch to 2010 IS350c
