IS C Discussion about the convertible IS C model
Interior/Dome Light Bulb Replacement IS350C
Old Dec 3, 2017 | 07:56 PM
jlshea's Avatar
jlshea
Question Interior/Dome Light Bulb Replacement IS350C
I’ve been searching without much luck on the method of removing the dome light/map light bezel on my 2014 IS350C.
It doesn’t look like any of the DIY photos that I’ve seen for IS models. I’m sure it’s different because it’s a convertible. It looks like there may be 4 clips on the bezel. Thanks in advance for any help!
Old Dec 4, 2017 | 04:01 AM
ed21x's Avatar
ed21x
You actually remove the entire assembly from the felt roof by prying it off using a plastic pry tool. after you remove them, the lights can be twisted off the back. i'm currently away on a business trip, but can take pictures once I get back at the end of the week.
Old Dec 10, 2017 | 12:24 PM
jlshea's Avatar
jlshea
Thank you, I would appreciate any photos if you have them. Would I pry from the front( near the windshield) or the back?
Old Dec 11, 2017 | 12:53 PM
ryanSC300lover's Avatar
ryanSC300lover
Are you updating the lights?
I am getting my new ISC tomorrow (waiting on transporter), so would love to know.
Old Dec 12, 2017 | 12:39 PM
jlshea29's Avatar
jlshea29
Yes I plan to swap out the dome light for LED bulbs. The map lights in the same housing already look like they are LED but the other 2 general bulbs are not.
Old Dec 12, 2017 | 12:43 PM
ryanSC300lover
Thank you. 4 more hours before my car gets here off the truck
Old Dec 13, 2017 | 04:49 PM
bbaugher47's Avatar
bbaugher47
I just bought an led dome light kit from Jdm toy. I am not sure if they have one for the isc though. Its a precut unit that has multiple leds. Have not put it in yet. ( no time)
Old Dec 13, 2017 | 09:04 PM
ryanSC300lover
Just got my car
Thought the map light were aftermarket. But you are right they like like OEM LED. I would like to match those to the dome for LED. I will keep watching this thread.
Old Dec 16, 2017 | 04:07 AM
ed21x's Avatar
ed21x
Sorry for the late reply. I just got back from a business trip. But anywhoo, changing the dome lights is quite easy.
Start by sticking a plastic pry tool in the following location and once you get a decent grip, just pull the entire dome light assembly down:
There are four clips that hold it in place. It takes quite a bit of force to pull down, but don't worry, nothing will break.
Once you've removed it, you'll see the two dome lights below (has the blue circles below). Twist it and that will enable you to access the bulb to change to LEDs. Only these two bulbs are not LEDs; all the other bulbs (reading lights) are already LEDs and don't need to be changed. The bulbs are your standard T5.
Old Dec 16, 2017 | 08:59 AM
ryanSC300lover
Thank you very much
Old Dec 16, 2017 | 11:45 PM
jlshea's Avatar
jlshea
Thanks so much, it went smoothly thanks to your instructions and photos! I didn’t imagine that the light assembly would have been clipped to the metal roof instead of the headliner. Thanks again!
Old Dec 17, 2017 | 01:03 PM
ryanSC300lover
Have you guys been able to do LED on the puddle lights on bottom mirror ?
Old Dec 18, 2017 | 08:55 AM
ed21x's Avatar
ed21x
Yeah, the process is the same as the regular 2is. We use the same assembly, so just need to find that thread.
Old Dec 18, 2017 | 09:13 AM
ryanSC300lover
Thank you, I will go search it now. Much appreciated.
Old Dec 18, 2017 | 09:17 AM
jlshea29's Avatar
jlshea29
I found a great video that walks through the swapping of puddle lights on the IS models. You tube,
If my link is not there go to youtube and search for
Lexus IS 250 350 F LED Install - 2006+
The puddle light change process is near the end of the video and this was exactly like my 2014 IS350C. Thanks.
