IS C Discussion about the convertible IS C model
Help- top won’t close fully or open
Old Feb 28, 2025 | 01:57 PM
QuietIs250c's Avatar
QuietIs250c
8th Gear
Default Help- top won’t close fully or open
Hey guys, after not opening the top for a bit, and since todays weather felt nice I decided to try to open the top at first you could hear the switch go off and start to open a bit, but out of nowhere it stopped and said “op suspended” so I tried to close it and it also said “op suspended” wondering if anybody else had this same issue. I tried to force to close it but it hasn’t closed and while I drive it says “roof halfway open “
Old Mar 1, 2025 | 03:48 AM
rwa930's Avatar
rwa930
10th Gear
did you unlock the trunk by prying up the small plastic cover between the back seats at the top. Use your manually key and turn till it clicks and opens the trunk. Mine says that intermittently but mine is fully closed. Started after battery change. Lexus found no codes on tech stream. It can be frustrating.
Old Mar 1, 2025 | 02:21 PM
QuietIs250c
8th Gear
Hey guys back with an update so It looks like it was just a first aid kit that was not letting the two panels come out or back in ( I’ll take a picture of the panels and first aid kit) every time I tried to close with the switch or open it would hear it work but it’s was because of the placement where the first aid kit was it was blocking the panels from moving
Panel would move to the right when switch is activated
By Coincidence the panel would be move to the right where the first aid kit would be that’s why it wouldn’t open
I was able to get to the trunk by using the override with my key fob and was able to open and move the first aid kit, thank god I didn’t agree at the dealer for the diagnose which would be 400 to start plus the labor and all… don’t make the same mistake I did
Old Mar 2, 2025 | 02:51 PM
ftrain's Avatar
ftrain
Whew! Glad you found that. I think those of us with these are just nervous that one day there will be a large bill coming for us to get the top working again. Happy for you!
Old Mar 5, 2025 | 08:44 PM
QuietIs250c
8th Gear
Yea I definitely agree on that with you 😂
Old Mar 31, 2025 | 01:36 PM
rossman1rb's Avatar
rossman1rb
10th Gear
Default Welcome to my world
My OP SUSPENDED nightmare is a bad package tray motor ($6800 dealer estimate). The damn thing just lifts a tiny flap and costs THAT much to replace? I’m looking for pointers from anyone that’s ever replaced one, btw, because there are several on EBay.
taylspen
Mar 25, 2018 09:46 AM
HOLGER21
Sep 20, 2012 09:29 PM
freshrice
Mar 17, 2010 08:35 AM
dhamaka127
Apr 15, 2007 08:59 AM
FlintRX
May 31, 2004 07:40 PM
